IR1101 - VLAN issue? Unable to ping
cadamwil
I wasn't sure if I should place this in the switching or routing sub-forum of Networking.  I have a IR1101 I have begun to setup.  This is the second I've setup and I mostly copied and pasted the config from the first IR1101, which is working as intended.  The only change I am aware of is I have added a Loopback interface to eliminate router from the ISP.
The issue I am experiencing is traffic on Port 1 and port 2 can't ping the routers'
VLAN1 interface of 10.78.55.1
from a device set to a static of
10.78.55.51
and DHCP doesn't seem to be working on those ports either.  Config attached.
Also, the scenario, in general I am trying to accomplish is this.
ISP normally provides a cheap home grade "wifi router" that is configured with
2.1.1.2
on it's WAN side and
2.1.2.1
on it's LAN side.  My device is supposed to be configured at
2.1.2.2
In order to eliminate an unreliable piece of equipment in a small box, I have configured the loopback at
2.1.2.2 and the GE as 2.1.1.2
The IR1101 is supposed to establish a VPN back to my city hall, and pass traffic from
FE0/0/1 and FE0/0/2
along that VPN allowing cameras to be recorded.  Let me know if I have left any needed details out.  I'm sure it's something simple I missed.
cadamwil
Issue turned out to be removing the
ip access-group Allow_CH_CCTV-to_LAN in
from the VLAN1 interface.  Worked with TAC to get it solved.
pieterh
the router has WAN / Layer3 interfaces
(routed, Gi0/0/0 and Gi0/0/1)
and LAN (Layer2) interfaces
( Fa0/0/0 - Fa0/0/x)
the Gi interfaces only work al Layer3 (routed)
the Fa interfaces  can be seen as a local switch within this route
so you need to treat them differently
the loopback interface will not replace (/function as) the providers ip-address
if you do not configure multiple VLANs all
Fa0/0/x
ports will be vlan1
the routers vlan-1 address will be reachable from the LAN side of the router
-> you need to connect your client to another
Fa0/0/x port
I think you DHCP does not function as desired because you do not allow DCHP broadcast in your
access-list
you can confirm this by adding an explicit deny rule at the end of the
access-list
with logging enabled
     deny any any log
cadamwil
