IR809 Cellular Dual-SIM LTE Failover not working
JoshG255
Hi all,
I'm trying to configure an IR809 router (single modem, dual sim) to have automatic sim failover, but I am having a lot of difficulties.
Two sims from two different carriers have been used. Both sims have been demonstrated to work with their configured profiles on the device in question.
In case it is relevant, this network will be using Phase 3 DMVPN across a network of hundreds of IR809s that need to have automatic LTE failover.
Goal:
SIM 1 is primary. SIM 2 is backup. Manually switch from SIM 1 to SIM 2 and back without reloading the router (router cannot go offline).
Bonus Goal:
When SIM 1 loses connectivity, automatically failover to SIM 2.
After a specified amount of time automatically fallback to SIM 1.
I have tried:
The problem I'm running into is:
Whenever the modem
resets/reloads/power-cycles
it does not change to the other SIM, and it also disconnects the existing working LTE connection, producing the below error every 10 seconds until I reload the whole router.
%CELLWAN-5-SIM_FAILOVER_TIMEOUT: [Cellular0]: SIM slot 1 Failover Timer timeout !!
The only way I have been able to consistently bring a cellular profile up is by reloading the router
The relevant config is in the file attached.
Please advise if additional information, config, or logs are needed.
2 Accepted Solutions
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/support/docs/interfaces-modules/lte-wireless-wan-interfaces/200455-Configuration-of-Dual-SIM-Feature-and-SI.html#anc6
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
JoshG255
I have been able to consistently get an IR809 to failover between SIMs with different carriers.
The steps I took to get LTE failover working consistently (that have not worked on previous days):
  • Copy and pasting the commands from the EEM script previously mentioned into the IR809 CLI
    NOTE - this did not work by manually typing in the commands, presumably because of timing
  • Wait (approximately 15 minutes) for the modem to restart itself 3 times before it comes up on the new SIM.
I agree upgrading to the latest firmware is a good first step to take, but the requirements of the client are very limiting.
Thanks for your help Marce!
8 Replies 8
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Hi M,
Thanks for your response!
The link you shared is actually referenced as not working in my initial post.
Do you have any ideas as to why?
 - Depends , does it work when you try the script manually ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
No it doesn't appear to.
With chat and modem debugs and logging console enabled, it seems to switch to the sim requested by the
activate
command, but then fail straight back over without allowing time for the modem to come fully online. Then when the modem finally does come back online with the original sim, the original sim profile never comes active and the below syslog message occurs every 10 seconds until the router is reloaded.
 - Use latest software version (if feasible and applicable)https://software.cisco.com/download/home/286287094/type/280805680/release/15.9.3M5
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Unfortunately we are not able to upgrade the firmware
due to the requirements of the existing network, but I haven't been able to find any related bugs regardless. This seems to be an issue with configuration, as both SIMs work on an individual level. It is simply the
failover process/commands
that don't work.
  >...we are not able to upgrade the firmware due to the requirements of the existing network, but I haven't been able to...
             - Still I consider that a show-stopper for resolving this problem  and or improving the situation.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
JoshG255
