12-10-2018 04:32 AM
So I am working with alot of PLC and they are a bit on the old side and uses Serial communication
On the IR 809 i want to use the Serial ports async 1 (RS232-DTE)
I manage to connect to that port by setting a IP on it and useing ssh.
But the SCADA systems do not ofcs use SSH.
how do i change tcp/udp ports?
12-10-2018 04:50 AM
I am not clear on what you are asking. Do you want to change the port used for SSH ?
IR809#conf t
IR809(config)#ip ssh port XXX rotary 1
where 'XXX is the new port'...
12-10-2018 05:08 AM
Hi Georg Pauwen
No so i have a Async port that will be used for PLC host to connect to.
where the IR809 well act as a convertor. IP/Serial
right now i can connect from the SCADA server to the Async port on SSH. but i need to change port as alot of the SCADA systems use Port tcp/5001
12-10-2018 11:34 AM
I am not sure I understand what you are asking. The async port by itself does not block anything. What do you want to connect with on the IR809 using port 5001 ?
12-10-2018 11:43 PM
Hello
So port 5001 is in this case what the Scada system uses. next time its tcp/5002 or udp/9523.
(we have a few diffrent Scada systems.)
So i need the modem to allow connections on any port.
Right now i only get tcp/22 to work. but i dont understand where i can change it.
Sorry Georg, English is not my first language.
the two pictures was of 1 program that tests Serialports and it worked on tcp/22 but no on tcp/5001.
12-11-2018 12:43 AM
your async port is probably configured like this:
interface Async0
ip address 10.128.7.33 255.0.0.0
encapsulation scada
At the bottom of the configuration you see lines like:
line 1/5
transport preferred none
transport output all
transport input all
I am not sure which line corresponds to your async port, check for one that says 'transport input ssh', since ssh is the only protocol working now. Change that line to 'transport input all'...
12-11-2018 01:18 AM - edited 12-11-2018 01:20 AM
interface Async0
ip address 10.128.7.33 255.255.255.254
encapsulation slip
end
stopbits 1
line 1/5
access-class PROC-AV1 in
transport input all
stopbits 1
if i use encapsulation scada it killes the interface.
So i use slip instead "slip = Serial Line IP"
Edit:
This guide says that async 0 belongs to 1/5 and 1/6 belongs 2 async 1
"Async 0 and Async 1 respectively reserve line 1/5 and 1/6 to relay serial data to the corresponding Guest OS /dev/ttyS1 and /dev/ttyS2"
12-11-2018 01:20 AM
what is in the access list ? What if you remove that from the line ?
line 1/5
--> no access-class PROC-AV1 in
transport input all
stopbits 1
12-11-2018 01:24 AM
ip access-list extended PROC-AV1
permit icmp any any
permit ip 10.128.7.0 0.0.0.255 host 10.128.7.33
deny ip any 10.128.7.0 0.0.0.255
permit ip any any
i removed it same results.
12-11-2018 01:40 AM
which emulator are you using ? I cannot tell from your pictures, but also try Putty and TeraTerm.
Under the async port, what others encapsulation options do you have ? I think ther also is ' encapsulation relay-line' ?
12-11-2018 01:51 AM
IR800(config-if)#encapsulation ?
bstun Block Serial tunneling (BSTUN)
ppp Point-to-Point protocol
raw-tcp Raw socket TCP
raw-udp Raw socket UDP
relay-line relay between lines
scada SCADA
slip Serial Line IP
trans Transparent data over MPLS mode
wpan WPAN
I used Putty, secure CRT. same reults, works on port 22 not on any other port!
No effect on relay-line
12-11-2018 01:55 AM
try 'encapsulation raw-tcp'; the screenshot with the successful SSH connection shows that a RAW TCP connection is detected...
12-11-2018 02:00 AM
12-11-2018 02:12 AM
try and configure the router as raw-socket tcp client or server:
12-11-2018 02:39 AM
