IR809 - Config Serialport
Niklas.D
So I am working with alot of PLC and they are a bit on the old side and uses Serial communication
On the IR 809 i want to use the Serial ports async 1 (RS232-DTE)
I manage to connect to that port by setting a IP on it and useing ssh.
But the SCADA systems do not ofcs use SSH.
how do i change tcp/udp ports?
17 Replies 17
Can you configure the client ?
I am not sure about the line numbers by the way. The example in the doc uses line 5:
line 5
raw-socket tcp client 10.0.0.254 5000
stopbits 1
Correct but that is a 807 and i have a 809.
Cant type Line 5
IR800(config)#line 5
No physical hardware support for line 5
IR800(config)#line 6
No physical hardware support for line 6
IR800(config)#line 4
No physical hardware support for line 4
IR800(config)#
IR800#sh run | sec line
line con 0
exec-timeout 5 0
logging synchronous
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
rxspeed 100000000
txspeed 50000000
line 8
no exec
rxspeed 100000000
txspeed 50000000
line 1/3
transport preferred none
transport output none
stopbits 1
line 1/4
exec-timeout 0 0
transport input all
transport output all
stopbits 1
line 1/5
exec-timeout 0 0
transport input telnet
stopbits 1
line 1/6
exec-timeout 0 0
transport input all
stopbits 1
line vty 0
access-class MGMT-ACCESS in
exec-timeout 5 0
logging synchronous
transport input all
line vty 1
exec-timeout 5 0
logging synchronous
line vty 2 4
exec-timeout 5 0
logging synchronous
transport input all
line vty 5 10
transport input none
IR800#
And i cant find a command to verify what line is used for async 0 or 1.
Colin Qld
Niklas,
Did you get to resolve this.  I believe the problem is the IP Addressing statement.
interface Async0
 ip address 10.128.7.33 255.255.255.254
 encapsulation raw-tcp
IP addressing is not on the Async interface, it's RAW Serial only with no IP.  A working solution is;
XXXXXXXX
interface Async0
no ip address
line 1
raw-socket tcp server 20000
XXXXXXXXXX
In this example router will listen on port 20000 on any IP interface (that's why you don't need the IP address under Async 0) in a similar way that SSH is accessible on any IP interface.  I configure a Loopback address and use access lists to limit traffic.  Depending on the serial requirements, you will need to configure stop bits, flow control, parity and data bits under Line 1.
