IR809 - Firmware upgrade fail
Niklas.D
So i am runing a IR809 Router, Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.9(3)M1, RELEASE SOFTWARE (fc1)
And when i try to upgrade the firmware i get this problem.
#bundle install flash:ir800-universalk9-bundle.SPA.159-3.M4.bin
Installing bundle image: /ir800-universalk9-bundle.SPA.159-3.M4.bin.....................................................................................................................................................................................................
updating Hypervisor image...
Starting File System integrity check
NOTE: File System will be deinited and later rebuilt
Starting partition 0 Analysis
Boot Sector/Boot Parameter Block check ...[Passed]
DIB not present
DIB & Monlib check ...[Passed]
Partition Init check ...[Passed]
Directory entries check ...[Passed]
SRP md5 verification passed!
updating IOS image...
Boot Sector/Boot Parameter Block check ...[Passed]Error
DIB not present
Creating orphan file: 10 4602
Creating orphan files under /ORPHAN1
Directory entries check ...[Passed] Error: failed to compute md5 hash for flash:/ir800-universalk9-mz.SPA.159-3.M4
IOS md5 verification failed!
Failed to remove corrupted IOS image: flash:/ir800-universalk9-mz.SPA.159-3.M4!
Now i have run a md5 check in the file is correct. i am upgradeing all my IR809 and the file works one alot of them.
It via ftp the file transfer.
Anyone got a Ide?
how did you do the MD5 check ? It should look something like the below:
verify /md5 flash:ir800-universalk9-mz.SPA.159-3.M4
