IR809 Router After Firmware Upgrade Consistently seeing this message
knadin
After performing a firmware upgrade, I get the message listed below.  The router is working, I see no issues in flash, meaning corruption. Trying to determine why I am seeing these messages and how I can turn this off or complete the
"check".  I am currently running "ir800-universalk9-mz.SPA.159-3.M3"
Starting File System integrity check
NOTE: File System will be deinited and later rebuilt
Starting partition 0 Analysis
Boot Sector/Boot Parameter Block check ...[Passed]
DIB not present
DIB & Monlib check ...[Passed]
Partition Init check ...[Passed]
Directory entries check ...[Passed]
5 Replies 5
Giuseppe Larosa
Hello @knadin ,
do you mean these messages appear at router boot or every few minutes ?
Hope to help
Giuseppe
Not exactly, when I press enter at a command prompt, I may get several in a row if I wait long enough. I can upload a screen shot
knadin
emiliolara
Did you find a solution?
emiliolara
It was my bad when I upgraded. I noticed that the HV file was the wrong one for the version 15.8(3)M6, I had the ir800-hv.srp.SPA.2.6.30 instead of the ir800-hv.srp.SPA.3.1.13 in the bootstrap:
So I went into ROMMON-1 and changed it to ir800-hv.srp.SPA.3.1.13.
And the message is gone now.
