IR829 - failed to boot
Bob_Rock
does anybody know how to resolve the issues regarding IR829 not booting.
I have write erased config on one of my routers, now router is not booting it cylcles like this over and over.
IR829 Loader Stage 1 Version 1.23
FPGA version 0x20b00 built 2020-4-8
Booted from the upgrade FPGA; SecureBoot did not fallback
Reset reason: software upgrade
BIOS Platform: IR800
BIOS Version: 27
SecureBoot core version: F01047R15.017cc1eea2019-02-08
Microloader version: MA0061R06.0404022015
Booted from the upgrade BIOS
Config reg configured to Autoboot
Autoboot is ON, variable: bootstrap:ir800-hv.srp.SPA.3.1.13
Image signature verified
Booting image bootstrap:ir800-hv.srp.SPA.3.1.13
[   20.186281] kexec: Starting new kernel
RIF heap (initial): 2774816 bytes
RIF<3> Added 2774816 bytes at <0x2015a8e0> to the RIF heap
RIF: Host RAM: 1467008KB required, 1467729KB available
RIF: Host low RAM: 4808KB required, 1467729KB available
RIF: Host RAM unused by memory regions: 721KB total, 721KB low
Processing SRP...
RIF: used 10568/16384 bytes of stack
   LynxSecure TRUNK (No Service Packs installed)
   Copyright 2004-2016 Lynx Software Technologies, Inc
   All rights reserved.
   LynxSecure (x86_64) build ENGINEERING created on 01/27/2016 09:35:28
   URL:         svn://txx.lynx.com/svn/lynxsecure/engr/psubramaniam/tot-20141010/lynxsecure/src
   Revision(s): 11396M
   Built by:    psubramaniam@paricos62.localdomain
   Initializing the Internal Timekeeping...
   Initializing the System State Manager...
   Initializing LynxSecure global data areas.
   Number of CPU(s) : 2
   Initializing the CPU Support Package.
   Initializing LynxSecure page table...
   Initializing the Board Support Package.
   Initializing Scheduler...
   Initializing the VCPU module...
   Starting up the other CPUs...
            CPUs online: #0 #1
   Initializing Device Configuration Virtualization...
   Initializing Subject Resources...
LS<3> DCV: device SATA0 (00:17.0) doesn't support generic reset
   Initializing Interrupt Routing...
   Initializing Hypercalls...
   Heap memory used by LynxSecure: 1766800 (0x1af590) bytes
   Launching Subjects
<3> [0.824164] IOAPIC: IOAPIC 1 initialized, implementation version 32
<3> [0.824164] <E1000> e1000_device_init: initialized E1000 device
<6> PCI: Initializing
<6> PCI: Finished Initializing
Autoboot string flash:ir800-universalk9-mz.SPA.157-3.M4b
Booting image: flash:ir800-universalk9-mz.SPA.157-3.M4b....   [Multiboot-elf, <
0x110000:0x9f299ec:0x3ca948>, shtab=0xa4052f8[csvds]:/ir800-universalk9-mz.SPA.
157-3.M4b... , entry=0x1100b0]
[CU:0]
Jumps to: 0x1100b0
Smart Init is enabled
smart init is sizing iomem
                 TYPE      MEMORY_REQ
    Onboard devices &
         buffer pools      0x03644000
               TOTAL:      0x03644000
Rounded IOMEM up to: 55MB.
Using 12 percent iomem. [55MB/448MB]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.7(3)M4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Tue 07-May-19 17:22 by prod_rel_team
cellwan_cwmp_init
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco IR829GW-LTE-GA-EK9 (revision 2.0) with 365568K/60416K bytes of memory.Installed image archive
Processor board ID FGL2446L3G2
Last reset from Firmware Upgrade
FPGA version: 2.B.0
BIOS: version 27 Production
BIOS: date[YYYY/MM/DD] :[2020/8/26]
MCU Bootloader : 28
MCU Application: 33
2 Serial(sync/async) interfaces
7 Gigabit Ethernet interfaces
9 terminal lines
2 Cellular interfaces
1 cisco Embedded AP (s)
DRAM configuration is 72 bits wide with parity disabled.
256K bytes of non-volatile configuration memory.
976562K bytes of ATA System Flash (Read/Write)
250000K bytes of ATA Bootstrap Flash (Read/Write)
 New Algorithm: Copied the BIOS upgrade image to Flash
New Algorithm: Update FPGA Upgrade image to Flash...
FPGA Image upgrade completed.
Starting File System integrity check
NOTE: File System will be deinited and later rebuilt
Starting partition 0 Analysis
        Boot Sector/Boot Parameter Block check ...[Passed]
        DIB not present
        DIB & Monlib check ...[Passed]
        Partition Init check ...[Passed]
        Directory entries check ...[Passed]
        DIB not present
Note: vds not reachable
Powering down cellular modem, please wait...
*Mar 18 14:13:44.871: %ACT2-5-STARTED: ACT2 process started.
*Mar 18 14:13:45.118: %LINEPROTO-5-UPDOWN: Line protocol on Interface wlan-ap0, changed state to up
*Mar 18 14:13:45.118: %LINK-3-UPDOWN: Interface GigabitEthernet5, changed state to up
*Mar 18 14:13:45.118: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Mar 18 14:13:46.550: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar 18 14:13:46.550: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet5, changed state to up
*Mar 18 14:13:46.550: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 18 14:13:50.397: %IR800_BIOS-2-IR800_BIOS_UPGRADE_REQUIRED: Running version: 27, available version: 24
*Mar 18 14:13:56.791: %IR800_FPGA-2-UPGRADE_REQUIRED: FPGA upgrade is in progress. Current version = 2.B.0, new version = 2.9.0. System will upgrade now and then reboot automatically.
*Mar 18 14:13:57.896: %IR800_FPGA-2-UPGRADE_COMPLETED: FPGA upgrade completed successfully.
*Mar 18 14:13:57.948: %SYS-5-RELOAD: Reload requested by FPGA/BIOS. Reload Reason: Firmware Upgrade Completed.
*Mar 18 14:13:59.000: %IR800_ENV-5-IR800_VDS_FAIL_NOTIFIED_GOS_SHUTDOWN: Failed to notified VDS for graceful shutdown.
How can i get into rommon ?
Thank you
Factory reset did not help, I had to boot in rommon-1, delete images, copy image from usb and boot that image.
So the router boots ok now ? If so, that sounds like a corrupted image file...
I mean It could be, but it's weird because if you use bundle install it checks the image in the process before installing it.
I used SCP to copy the image from our server.
