"domain" vs. "ip domain-name" global configuration commands
coolbreeze
Might someone be able to help explain the difference between the following global configuration mode "domain" commands their effects:  domain [domain name]  vs.  ip domain name [domain name]
Below is some example output of what I am seeing on two different Cisco ASR 1006X WAN aggregation hub routers, running same firmware version.
$$$$$$$$$$$ BEGIN ROUTER 1 SAMPLE OUTPUT $$$$$$$$$$$$$$
Router1#show version
Cisco IOS XE Software, Version 16.09.02
Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.2, RELEASE SOFTWARE (fc4)
Router1#
Router1#sh run | inc domain
no ip domain lookup
ip domain name example.com
domain example.com
Router1#show domain all
 *** DOMAIN NAME:   example.com ***
Router1#
$$$$$$$$$$$$ END ROUTER 1 SAMPLE OUTPUT  $$$$$$$$$$$$$$
$$$$$$$$$$$ BEGIN ROUTER 2 SAMPLE OUTPUT  $$$$$$$$$$$$$$
Router2#show version
Router2#
Router2#sh run | inc domain
Router2#show domain all
Router2#
$$$$$$$$$$$$ END ROUTER 2 SAMPLE OUTPUT  $$$$$$$$$$$$$$
balaji.bandi
As per your show output show that you using IOS XE Code.
based on that my comments :
domain
Configures the fabric domain and enters fabric-auto-domain configuration mode. The no version of this command deletes the fabric domain.
domain { default| name name }
no domain
Syntax Description
default
Configures the default fabric domain and enters fabric-auto domain configuration mode.
name name
Configures a new fabric domain and enters fabric-auto domain configuration mode.
Ip  Domain Name :   ( traditional domain config)
Defines a default domain name that the Cisco IOS software uses to complete unqualified host names (names without a dotted-decimal domain name).
BB
balaji.bandi
domain
no domain
Syntax Description
default
name name
BB
Thank you, for whatever reason I was having difficulty finding the right command reference for those for the version that included the "domain" command referring to the fabric domain.  Now I'm just doing a facepalm, but you answered my question, thank you!
