IS-IS P device cannot ping C device, 4 hops away
TanmaySarkar
This is my Topology, where my P-2, P-3 and devices after P-3 are unable to ping or traceroute CE-1 and C-1 devices.
Output is either-
*Oct 19 00:50:17.023: ICMP: dst (10.10.10.2) port unreachable sent to 10.10.40.5
OR, Other output is-
*Oct 19 00:54:16.139: ICMP: echo reply sent, src 10.10.10.1, dst 10.10.50.6, topology BASE, dscp 0 topoid 0
------------------------- So, my question is how many hops should I be able to ping if I have an IS-IS topology of all level-1, level-2, and level-1-2 in it?
Kindly reply I am unable to figure out what should I do. I wish this topology works with Summarization and Redistribution.
Redistribute connected is one way to redistribute between routing protocols. There are also route maps and full redistribution of the other routing protocol among other methods.
5 Replies 5
hard to tell without seeing the configs. This looks like a GNS3 file, can you post the topology file ?
Dear George,
I am really sorry, I got tired and deleted the topology, but my question is, do we need to write - "Redistribute Connected" every time we redistribute EIGRP to ISIS? and what if I use OSPF? Do I need to write this command in case of OSPF also?
Thank you for the Reply Sir.
Jonathan Cuthbert
In your topology, the strict Level-1-Only routers (C-1/C-2) will have no route to the strict L-2-Only routers (P-1, P-2, P-3). This is also dependent on how your areas are configured, too.
I am not sure what exact IP address you used, but when I mocked up your topology, I used the following.
C-1 = .1
CE-1 =.2
PE-1 = .3
P-1 = .4
P-2 = .5
P-3 = .6
PE-2 = .7
CE-2 = .8
C-2 =.9
The NET of the router is 49.0000.####.####.####.00
It is a large flat area.
From P-1
P-1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 10 subnets, 2 masks
i L2     10.10.10.0/24 [115/30] via 10.10.30.3, 00:14:06, GigabitEthernet0/0
i L2     10.10.20.0/24 [115/20] via 10.10.30.3, 00:14:06, GigabitEthernet0/0
C        10.10.30.0/24 is directly connected, GigabitEthernet0/0
L        10.10.30.4/32 is directly connected, GigabitEthernet0/0
C        10.10.40.0/24 is directly connected, GigabitEthernet1/0
L        10.10.40.4/32 is directly connected, GigabitEthernet1/0
i L2     10.10.50.0/24 [115/20] via 10.10.40.5, 00:13:56, GigabitEthernet1/0
i L2     10.10.60.0/24 [115/30] via 10.10.40.5, 00:13:56, GigabitEthernet1/0
i L2     10.10.70.0/24 [115/40] via 10.10.40.5, 00:13:56, GigabitEthernet1/0
From C-1
C-1#show ip route
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C        10.10.10.0/24 is directly connected, GigabitEthernet0/0
L        10.10.10.1/32 is directly connected, GigabitEthernet0/0
i L1     10.10.20.0/24 [115/20] via 10.10.10.2, 00:15:47, GigabitEthernet0/0
This can be confirmed with a traceroute from P-1 to CE-1 and P-1 to C-1.
P-1#traceroute 10.10.10.2
Tracing the route to 10.10.10.2
VRF info: (vrf in name/id, vrf out name/id)
  1 10.10.30.3 48 msec 36 msec 8 msec
  2 10.10.20.2 40 msec 20 msec 28 msec
P-1#traceroute 10.10.10.1
Tracing the route to 10.10.10.1
  1 10.10.30.3 8 msec 16 msec 20 msec
  2 10.10.20.2 16 msec 36 msec 36 msec
  3  *  *  *
  4  *  *  *
P-1#
The level-2 routers have knowledge of the level-1 topology because the L1/L2 routers are advertising the L1 routes into the L2 LSDB.
The L1/L2 routers use the attached bit to advertise networks in different areas.  So it depends how you did your areas, too.
Using strictly IS-IS, the C-1/C-2 routers have no knowledge on how to reach anything but their CE router and its interfaces.
You can solve this by creating a static default route on C-1/C-2 which would be common to see in deployment.  You can also redistribute (route leak) the L2 routes into L1.  Either is a valid solution.
