Soft loop test a T1
JTx
I performed the following steps:
Router#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#controller t1 0
Router(config-controller)#no pri-group timeslots 1-24
Router(config-controller)#channel-group 0 timeslots 1-24 speed 64
!--- This automatically creates a single Serial0:0 interface.
Router(config-controller)#loopback local line
!--- The loopback local command above is only necessary for software loopbacks.
Router(config-controller)#exit
Router(config)#interface serial 0:0
Router(config-if)#encapsulation hdlc
!--- Note: All loopback testing is done with hdlc encapsulation.
However, the interface shows UP/DOWN and I cannot (locally)  generate ping packets to the IP address configured on this interface.
Serial0/0/1:0 is up, line protocol is down
Hardware is DSX1
T1 0/0/1 is up. (Local Line Loopback)
Applique type is Channelized T1
Cablelength is long 0db
Receiver has no alarms.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info FPGA Rev: 08121917, FPGA Type: PRK4
Framing is ESF, FDL is ansi & att, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
I want to perform a soft loop test to rule out any potential issues with the T1 card/port.  I plan to send ping packets to the IP addresss configured on that port.
I have noticed that sending packets size equal or larger to 300 bytes causes a packet drop pattern, the ISP says that the issue might be on our end.
Thanks in advance.
Hello @JTx
Usually Serial0/0/1:0 is up, line protocol is down means different encapsulation on both both side. You are using HDLC, confirm which Encapsulation ISP is currently using.
-If I helped you somehow, please, rate it as useful.-
Thanks Flavio,
I checked with the ISP, they are using PPP. But even if I set the serial interface to PPP the interface remains UP/DOWN  when the "loop local" command is applied under Controller T1 0/0/1.
If they are using PPP you need to use it as well. They need to speak the same language.
Can you share the show run from this device?
Flavio Thank you so much.  Changing  the encapsulation to HDLC actually worked!
I do have another question, though. I tested the Serial interface with the loop in place from the provider and I got a weird pattern:
RTR#ping 172.16.255.129 rep 1000 size 1500
Sending 1000, 1500-byte ICMP Echos to 172.16.255.129, timeout is 2 seconds:
Success rate is 90 percent (900/1000), round-trip min/avg/max = 20/22/100 ms
Serial0/0/1:0 is up, line protocol is up (looped)
Hardware is DSX1
Internet address is 172.16.255.129/30
MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Last input 00:00:08, output 00:00:08, output hang never
Last clearing of "show interface" counters 00:25:07
Queueing strategy: fifo
Output queue: 0/40 (size/max)
3958 packets input, 5723962 bytes, 0 no buffer
Received 156 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3958 packets output, 5723962 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 carrier transitions
T1 0/0/1 is up.
No alarms detected.
Data in current interval (258 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
Any idea what might be causing this? Thanks in advance
