IS-IS route flapping
RP/0/RSP0/CPU0:PE1# sho route 10.x.47.25
Fri Feb  2 12:00:28.308 BKK
Routing entry for 10.x.47.25/32
  Known via "isis 47", distance 114, metric 20, type level-2
  Installed Feb  2 11:57:33.751 for 00:02:54 => it's never more than 5 minutes
  Routing Descriptor Blocks
    10.2.1.2, from 10.x.47.25, via Bundle-Ether11
      Route metric is 20
  No advertising protos.
RP/0/RSP0/CPU0:PE1# ping 10.x.47.25
Success rate is 0 percent (0/5)
RP/0/RSP0/CPU0:PE1# sho isi nei be11 det
Fri Feb  2 12:06:27.494 BKK
IS-IS 47 neighbors:
System Id      Interface        SNPA           State Holdtime Type IETF-NSF
PE2          BE11             *PtoP*         Up    27       L2   Capable
  Area Address(es): 49.0233
  IPv4 Address(es): 10.2.1.2*
  Topologies: 'IPv4 Unicast'
  Uptime: 01:19:45
RP/0/RSP0/CPU0:PE1# pin 10.2.1.2 siz 9000 cou 9000 don int 3
Success rate is 100 percent (9000/9000), round-trip min/avg/max = 1/1/651 ms
10.x.47.25 is the loopback 0 of connected router with dark fiber. How should I do?
Thank you very much.
I tried to reload another side (ASR900), it solved.
How
Are you aware of any physical issue, unstable links ?
Show cpu process sorted - Do you have high cpu utilization? -
Sh clns neighbors  -  no both peering rtrs
Sh logging
res
Paul
Kind Regards
Paul
hard to determine what causes the flapping without seeing the configurations, can you post those ? I have a feeling that it has to do with IS-IS running over an EtherChannel (which uses a lload balancing scheme that might disrupt IS-IS).
Can you post the output of 'show interfaces x' where 'x' are the interfaces on both sides (this is to check if there are errors or dropped packets on these interfaces) ?
Hello Experts,
I am doing re-design my customer network, can someone tell me how many routers we can have per IS-IS process.
How many processes, instances, routes supported by routers (ASR9K, ASR 903, ASR902, ASR901, ASR 920).
RSPs (RSP3, RSP1A and RSP2B).
I will be very thankful.
Mohammad Wasif
