BGP sessions monitoring.
Hi,i have 4 BGP peers (ISP) connected to my WAN routers.
I want to monitor in real time how many active routes i received from each of the peers.I was unable to find the coresponding MIB.
Do you have some better scenarios/software to perform BGP monitoring ?
Thanks.
Dan Frey
I believe your looking for this OID in the CISCO-BGP4-MIB:
cbgpPeerAcceptedPrefixes OBJECT-TYPE
    SYNTAX          Counter32
    MAX-ACCESS      read-only
    STATUS          current
    DESCRIPTION
        "Number of accepted route prefixes on this connection,
        which belong to an address family."
    ::= { cbgpPeerAddrFamilyPrefixEntry 1 }
- Dan
Dan Frey
    SYNTAX          Counter32
    STATUS          current
    DESCRIPTION
- Dan
Thanks.
Based on your information i founded this document.
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&mibName=CISCO-BGP4-MIB
In there are all the MIB`s i can dream of
Thanks again
Is there any OID to monitor bandwidth of BGP session: Example, I have 3 BGP sessions over same 1 physical link, so I want to monitor bandwidth of each BGP session
