IS-IS Support C921
I try to find out if C921 routers support IS-IS. The feature navigator does not seem to know the platform. Does anyone have an IS-IS network including this type of routers?
Harold Ritter
Hi @MATTHIAS SCHAERER ,
IS-IS is not supported on this platform. Please refer to the following data sheet.
https://www.cisco.com/c/en/us/products/collateral/routers/900-series-integrated-services-routers-isr/datasheet-c78-741615.html
7 Replies 7
Mark Elsen
  - Ref : https://www.cisco.com/c/en/us/td/docs/routers/access/900/software/configuration/guide/900SCG/routconf.html
             I could find several references to IS-IS with Find in the browser in command outputs. So it looks like it but
             I guess that those views are not authoritative ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Harold Ritter
Thanks Harold, not what I hoped to read but it really seems to be that way.
You are very welcome @MATTHIAS SCHAERER and thanks for the feedback
Harold, may I come back to you?
I have received two test C921 routers that seem to be talking ISIS without any issue. I'm a bit puzzled now. ISIS is in IOS but not supported? Here's some config snippet and a "sh ver":
test-router-9998#sh run | s r i
ip router isis 1
ip router isis 1
router isis 1
vrf isis
net 49.0000.0000.0000.9998.00
is-type level-2-only
authentication mode md5 level-2
authentication key-chain ISIS-KEY level-2
metric-style wide
fast-flood 10
set-overload-bit on-startup 360
max-lsp-lifetime 65535
lsp-refresh-interval 65000
spf-interval 5 50 200
prc-interval 5 50 200
lsp-gen-interval 5 50 200
no hello padding point-to-point
log-adjacency-changes
passive-interface Loopback0
test-router-9998#sh ver
Cisco IOS Software, C900 Software (C900-UNIVERSALK9-M), Version 15.8(3)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Thu 28-Mar-19 21:16 by prod_rel_team
ROM: System Bootstrap, Version 15.8(3r)M0b, RELEASE SOFTWARE (fc1)
test-router-9998 uptime is 22 hours, 25 minutes
System image file is "flash:c900-universalk9-mz.SPA.158-3.M2.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C921-4PLTEGB (revision 1.0) with 994825K/53750K bytes of memory.
Processor board ID xxxxxxxxxxxx
6 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
1 Cellular interface
256K bytes of non-volatile configuration memory.
1900544K bytes of SD Flash flash (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 C921-4PLTEGB xxxxxxxxxxx
Technology Package License Information for Module:'c900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
appx None None None
test-router-9998#
I have not seen any reference that would confirm the fact that IS-IS is officially supported on this platform.
Although it is visibly available in the CLI, you should contact your Cisco system engineer (SE) to confirm the official support of this protocol on this specific platform.
Harold, that's what I've done. Thanks for getting back again.
