Is it compatible with each other?
Soon Kwan Kwon
Hi all,
I'm wondering if possible one another? like this.
1. 2960-XR series
2. Cisco router 1841, 1721
I'll connect it each other using UTP cable.
But, you know, 2960-XR's fiber support 1Gigabit, but router 1841,1721 support 10/100.
Is is compatible with 2960XR series and 1841, 1721 indeed?
I think it is possible...
Anyway, I want to know whether supporting "compatible".
Mark Malone
Yes those devices will work together they can auto negotiate the speed or you can hard set it
Mark Malone
Thank you sir^^
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Just wanted to also note, smaller/older routers, even though they have FE or gig interfaces, often their forwarding performance cannot keep up with sustained FE or gig rates.
