07-05-2021 01:21 PM
Hi Everyone,
Is there anyone that can help me I am struggling to see if you can bridge a Cisco C1117-4P router. As I cant seem to get the device to talk to another Aerohive XR600P router. We are trying to test a solution that I want to use with some point to point connections.
I have attached the config of the router. Can you guys please help me as I used the guides from the cisco site but not getting it working?
Solved! Go to Solution.
07-06-2021 08:08 AM
Hello @MarcelSmal ,
look for a routed alternative as bridging is not available between the ATM interface and the LAN interface on the Cisco router.
You can even use NAT on the Cisco router as a way to help the downstream device to reach the internet.
Hope to help
Giuseppe
07-05-2021 01:54 PM
IOS-XE doesn't support the legacy bridge groups, it uses BDI. Check the document below. IP Base should in theory be sufficient. Can you create service instances ?
07-05-2021 03:02 PM
Is it possible to bridge a C1117-4P and a Aerohive Router?
not sure we understand your question, you want to make 2 bridge devices to pass the traffic ?
we miss the config you mentioned here?
07-05-2021 11:32 PM
@inderdeeps I see thought that it will be possible as I read somthing like the article that you posted.
@balaji.bandi I want the cisco router to act as the bridge and pass the adsl connection traffic to the other router.
I see the config was not attached.
Router#sh run
Building configuration...
Current configuration : 4031 bytes
! Last configuration change at 14:36:35 UTC Mon Jul 5 2021
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ip routing
login on-success log
subscriber templating
Crypto Config removed
diagnostic bootup level minimal
redundancy
mode none
controller VDSL 0/2/0
training log filename flash:vdsllog_0-2.bin
vlan internal allocation policy ascending
bridge irb
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface ATM0/2/0
no ip address
atm oversubscribe factor 2
no atm ilmi-keepalive
no atm enable-ilmi-trap
interface ATM0/2/0.1 point-to-point
description connection to service provider
atm route-bridged ip
pvc 0/34
vc-hold-queue 1024
encapsulation aal5snap
interface Ethernet0/2/0
no ip address
no negotiation auto
service instance 100 ethernet
encapsulation untagged
bridge-domain 100
interface Vlan1
no ip address
interface Dialer1
no ip address
encapsulation ppp
dialer pool 1
dialer remote-name Router3
dialer string 5553434
dialer-group 2
no cdp enable
ppp authentication chap
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
dialer-list 1 protocol bridge permit
control-plane
Login details removed
end
Router#
07-06-2021 03:46 AM
Hello @MarcelSmal ,
your WAN interface is the following:
pvc 0/34
vc-hold-queue 1024
if this sub intereface does not accept the command bridge domain 100 you cannot bridge.
Try and report the results.
Hope to help
Giuseppe
07-06-2021 07:36 AM
Thanks for letting me know.
@Giuseppe Larosa when I try to issue that command it gives me a % unrecognized command. So it seems that you cant bridge it like I need it to.
07-06-2021 08:08 AM
Hello @MarcelSmal ,
Hope to help
Giuseppe
09-13-2022 10:38 PM
Sorry to resurrect this thread. I'm trying a similar thing with the same C1117-4P. The difference is I don't use PPPoE, so no Dialer interface.
Wouldn't it be possible to bridge Ethernet0/2/0 with GigabitEthernet0/1/0, or does that still count as the "ATM" interface. When I looked at https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/bdi.html it said the only limitation there was "PPP over Ethernet (PPPoE)".
