Is it possible to use LACP and NAT over Layer3 port-channel?
mw6949
Cisco 4351
NAT is a private network setup to map with public network to access but LACP is an etherchannel setup mainly made up of routers,switches and servers by means of sharing in the process of using two links to activate as one link and if one link fail,the other link can pass data and I think regardless of accessing data in NAT or in the public network
I think it acceptable,
since the LACP is L3 not L2 then you can config NAT under PO L3 interface.
