Cisco 1941 Router connecting to NetGear Router
lfleisher
Hello!
I'm a networking Student and I've recently made bounds and leaps in my HomeLab (trivial to some of you but huge to me).
I'm running into one issue that my hours of Youtube and Googling I have not been able to come up with an answer.
Here is a Topographical view of my Network:
For Hardware I have:
Cisco 1941 Router x1
Cisco 2960 Switch x1
Windows 11 Laptop x2
Windows Server x1
NetGear Router
(The computers are running Windows, they obviously aren't enterprise)
Network Information:
I have the following VLAN's and associated pools:
Inter-vlan Routing works along with DHCP Helper handing out addresses from each pool.
On my Cisco Switch I have Interface G0/0 set to accept a DHCP address from my NetGear router. My intent is to route the information from my HomeLab out to the internet so I can move on a finish my routing/switching and get into security labbing.
Interface G0/0 has a 172.16.0.3 address as given by my NetGear Router (172.16.0.1 Gateway).
Interface G0/1 does not have an assigned IP Address but has Sub-interfaces:
  • G0/1.5 (NATIVE)
  • G0/1.99
  • G0/1.201
  • G0/1.300
  • G0/1.800
From the CLI on the router I can ping out to Google (8.8.8.8) I can also ping the HomeLab LAN.
However, I run into an issue when attempting to ping from G0/1 -> G0/0 and vice-versa. I've tried setting up IP NAT inside, outside and access-lists. I have attached the Routers SH RUN.
Does anyone have any advice?
balaji.bandi
Try below config :
no ip default-gateway 172.31.255.1
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 172.16.0.1
no ip route 0.0.0.0 0.0.0.0 172.16.0.1 254
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
access-list 1 permit ip 192.168.1.0 0.0.0.255 any
access-list 1 permit ip 172.16.255.0 0.0.0.255 any
access-list 1 permit ip 10.0.255.0 0.0.0.255 any
nterface GigabitEthernet0/1.99
ip nat inside
interface GigabitEthernet0/1.201
ip nat inside
interface GigabitEthernet0/1.300
ip nat inside
interface GigabitEthernet0/1.800
ip nat inside
BB
balaji.bandi
Try below config :
ip nat inside
ip nat inside
ip nat inside
ip nat inside
BB
This worked! thank you so much!
