Is my ZBFW too permissive?
netmon-27
Hi everyone,
I've just gotten my very own Cisco 2901 ISR for experimenting. The IOS software is updated to 15.7(3) and basic routes are setup and working. I'm at the point now where I'd like to secure it for general use in my LAN. I've gone through a few tutorials to get a basic Zone-Based Firewall setup, and with most protocols matching outbound, it seems to be working alright.
One immediate issue I can see is that my email client, Thunderbird, can no longer connect to outside IMAP servers. The imap protocol is matched in my policies, but when it connects via TCP/TLS, the packets are dropped. As far as I can tell, my only option is to allow all TCP and UDP going outside my network. Is this unreasonable, or is it ok?
Hello
Can you post your ZBFW configuration?
Kind Regards
Paul
Sorry, should've done that to begin with! I originally did some configuration in CP Express (before it stopped working) and that was where I assigned the gigabit ethernet module to Vlan1 (gi0/1/x) but I honestly cannot tell you where, looking at the config, that happens. Maybe ports default to Vlan1?
Access lists
ip access-list standard NAT
 permit 192.168.1.0 0.0.0.255
ip access-list extended Others_acl
 permit object-group Others_svc object-group Others_src_net object-group Others_dst_net
ip access-list extended Web_acl
 permit object-group Web_svc object-group Web_src_net object-group Web_dst_net
ip access-list extended nat-list
 permit ip object-group local_lan_subnets any
Object groups
object-group service INTERNAL_UTM_SERVICE
object-group network Others_dst_net
any
object-group network Others_src_net
any
object-group service Others_svc
ip
object-group network Web_dst_net
any
object-group network Web_src_net
any
object-group service Web_svc
ip
object-group network local_cws_net
object-group network local_lan_subnets
any
object-group network vpn_remote_subnets
any
Class maps
class-map type inspect match-any INTERNAL_DOMAIN_FILTER
 match protocol msnmsgr
 match protocol ymsgr
class-map type inspect match-any Others_app
 match protocol https
 match protocol smtp
 match protocol pop3
 match protocol imap
 match protocol sip
 match protocol ftp
 match protocol dns
 match protocol icmp
! I made the below class b/c I thought I needed it for pings to WAN to work (maybe not?)
class-map type inspect match-any Basic-Input-Class
 match protocol icmp
class-map type inspect match-all LAN-WAN-Class
 match access-group name Others_app
class-map type inspect match-any Web_app
 match protocol http
! Catch-all class I created so traffic can go out
class-map type inspect match-any ALL-MISC
 match protocol tcp
 match protocol udp
class-map type inspect match-all Others
 match class-map Others_app
 match access-group name Others_acl
class-map type inspect match-all Web
 match class-map Web_app
 match access-group name Web_acl
Policy maps
! Outbound policy that as far as I can tell lets everything go out. Is this bad?
policy-map type inspect LAN-WAN-POLICY
 class type inspect Web
  inspect
 class type inspect Others
  inspect
 class type inspect ALL-MISC
  inspect
 class class-default
  drop log
! Inbound traffic that should only let pings in (basic input class)
policy-map type inspect WAN-LAN-POLICY
 class type inspect Basic-Input-Class
  inspect
 class class-default
  drop log
Security zone pairs
zone security LAN
zone security WAN
zone security VPN
zone security DMZ
zone-pair security LAN-WAN source LAN destination WAN
 service-policy type inspect LAN-WAN-POLICY
zone-pair security WAN-LAN source WAN destination LAN
 description From WAN to LAN
 service-policy type inspect WAN-LAN-POLICY
Interfaces
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description PrimaryWANDesc_
 ip address dhcp hostname router-cisco
 ip nat outside
 ip virtual-reassembly in
 zone-member security WAN
 duplex auto
 speed auto
 ipv6 address autoconfig
 ipv6 enable
! Old port I had setup for management - no longer used.
interface GigabitEthernet0/1
 ip address 10.0.0.1 255.255.255.248
 duplex auto
 speed auto
! GbE switch module mapped to Vlan1
interface GigabitEthernet0/1/0
 no ip address
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 no ip address
interface GigabitEthernet0/1/3
 no ip address
interface GigabitEthernet0/1/4
 no ip address
interface GigabitEthernet0/1/5
 no ip address
interface GigabitEthernet0/1/6
 no ip address
interface GigabitEthernet0/1/7
 no ip address
interface Vlan1
 ip nat inside
 zone-member security LAN
 ip tcp adjust-mss 1460
 ipv6 address prefix-from-provider ::100:0:0:0:1/64
 ipv6 enable
NAT & Route
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip nat inside source list nat-list interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 dhcp
