Connecting multiple routers for single switch
Surabhi
Need help!!!
We are receiving internet service with /27 IPs .From the ISP provider's router we are connecting to a layer 2 switch, from that switch we are connecting different router as per our requirements like sd-wan, WIFI,LAN Etc. We don't have any VLAN configuration at the switch.
Please check the diagram for example.
We are seeing bandwidth degradation at our LAN , we are supposed to get 100mbps but we are getting only 9mbps.
I am assuming something is wrong.
balaji.bandi
If the Switch acting as Layer 2 yes that is the way to connect (no other things done on the switch)
100MB inside the Lan ? from what device to what device are you testing?
100Mega bits per second?  transfer always Megabytes per second - please check and clarify ?
while you transferring the files or speed test,  on the switch port what do you see show interface fas x/x transfer rates?
BB
depend on SW technology,
this SW only connect L3 device so prefer to be cut-through not store-and-forward image.png
