Is password-recovery works on router turn on with radius??
aansatosorigin
/message/3036844;jsessionid=AB2E3193D00FC98600C816D2BB58780E.node0#3036844Hi Experts,
I have turn on AAA to enable radius authentication. However, I failed to login using the generated password by radius server, which end up I can't log into the router at all. To access this router again, I disconnected the router from LAN and tried using password-recovery measure but still fail. During password-recovery process, I have pressed ctrl+break couple of time but still fail to enter the romon mode.I've been doing this process more than 20 times but seems no use at all. Fyi, I m using router 2811. Really appreciate your advice on how to recover the password again.
Leo Laohoo
1.  Power off the 2811 router.
2.  Pop the CF.
3.  Turn on the router and wait until it boots into ROMmon.
4.  Insert the CF but DO NOT BOOT yet.
5.  Perform password recovery and boot the router.
Leo Laohoo
2.  Pop the CF.
THANK YOU!
Thank you for the ratings and glad to be of some assistance.
