Is QOS needed for LAN ?
musthafa786
In my network,  access switches are 3750, distribution and core switches are 6509 E switches, access switches are connected with Gig ports to distribution switches, and  distribution and core switches are connected with TenGig ports...
Is it necessary to configure QOS configuration inside the LAN for the better traffic flow or performance? ( In my network , there are many critical real time datas)
Musthafa.
Terry Cheema
Its always a best practice to configure QoS end-to-end on all qos aware devices. You should configure QoS in your LAN, its best to mark traffic closest to source. Specialy if you have real time applications, its even more recommended. Most of the real time servers will mark (or you can configure them) the real time traffic with appropriate markings. You can trust it simply or you can classify and mark using other mechanisms like acls etc.
Go through the below link - it has all the info you require for different models:
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoSDesign.html
Terry
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Necessary? Maybe - depends on whether there's any congestion that's adverse to your traffic due to bandwidth competing less critical traffic.
