I'm upgrading my cBR8 from 17.9.1w to 17.12.1x. My SUP ROMMON is 16.7(8r)S. In Table 1 (or 3 depending on doc version) Firmware Versions it says the minimum required version is 16.7(9r)S so mine is a version older (16.7(8r)S). But in the section "Upgrading from 16.x or later" section it says to upgrade the SUP ROMMON if your upgrading from Everest 16.6.x or Fuji 16.7.x and in section "Upgrading from 17.6.1z or Later images" it doesn't even mention upgrading the SUP ROMMON. So, I'm trying to understand if I need to upgrade the SUP ROMMON or not. I appreciate any guidance.
