Is there a "ip tcp adjust-mss" equivalent command for NX-OS
Giovanni Ceci
Hey Community,
Is there a "ip tcp adjust-mss" equivalent command for the NX-OS? We have a few GRE tunnels and best-practice is to configure this command on both ends but the command is not there.
Please help!
John
You can use following configuration instead of former command:
#interface tunnel 0
-if)#mtu 1600
-if)#ip access-group DLP in
-if)#ip address <><>
#ip access-list extended DLP
-acl)#statistics per-entry
-acl)#deny ip any any packet-length gt <adjust value>
-acl)#permit ip any any
I think, it may helps you.
Houtan
This is Not Solution You Drop Packet Donnot change tcp mss
