Is there a way to exempt GRE traffic to be NATed?
ftenerelli
Im trying to establish a DMVPN with a HUB and 2 Spokes, but for the HUB LANs i need to static NAT the firewall outside interface (is a clearOS machine that act as a default gateway for LANs), and whenever i apply the NAT the DMVPN goes down...
Now im trying to no-nat the GRE traffic like this:
access-list 101 deny gre any any
access-list 101 permit ip host 10.255.255.2 any
route-map nonat permit 10
match ip address 101
ip nat inside source static 10.255.255.2 X.X.X.X route-map nonat
But still after a
 show ip nat translation | i gre
gre X.X.X.X:0 10.255.255.2:0 Y.Y.Y.Y:0 Y.Y.Y.Y:0
gre X.X.X.X:0 10.255.255.2:0 Z.Z.Z.Z:0 Z.Z.Z.Z:0
This is the network diagram , for testing purposes im not running it with IPSEC.
Where X.X.X.X is the HUB public IP and YYYY/ZZZZ are the Spokes public IP. And 10.255.255.2 is the clearOS outside interface.
I think that if the gre traffic is prevented from being NATed the problem is solved, but the ACL wont make matches on the first sentence, so i only have internet traffic but no VPN.
Hello.
You are on the right way - just missing "reversible" keyword in the translation.
Hello.
HI Vasiliii thanks a lot that was the solution!.
