Comtech serial problem
ciscocrank
Dear Sir or Madam
I have Comtech modem CDM 570L and it is working fine butI upgraded my serial cisco interface from normal serial (WIC -1t ) to cisco smart serial (WIC -2t ) I had to change the cable between modem and router of cource I used cable (CAB-SS-530MT ) and I am using RS422 protocol in modem .
the problem is that the router doesn't sense the cable at all it looks like there is no cabe , I check WIC , router and cable it is all working , does comtech support smart serial , any advice to help
7 Replies 7
paolo bevilacqua
Can you send output of "show controllers" for the serial interface ?
Hello
I attached the show controller output and below is the show interface result
Serial0/0/0 is down, line protocol is down
Hardware is GT96K Serial
MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
Encapsulation FRAME-RELAY IETF, loopback not set
Keepalive not set
Restart-Delay is 0 secs
LMI DLCI 1023 LMI type is CISCO frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
Last input never, output never, output hang never
Last clearing of "show interface" counters 3d01h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 carrier transitions
DCD=up DSR=up DTR=down RTS=down CTS=up
Hi, either WIC or the cable is defective:
Interface Serial0/0/0
Hardware is GT96K
No serial cable attached
hello
thanks very very much,
I changed the cable and I got the same problem,
but when I used another cable type , (CAB-SS-232MT) , the wic sense the cable but still have no connection
sh controller
Hardware is GT96K
DTE V.24 (RS-232)idb at 0x4304F664, driver data structure at 0x43056D80
wic_info 0x4305737C
Physical Port 1, SCC Num 1
MPSC Registers:
MMCR_L=0x000304C0, MMCR_H=0x00000000, MPCR=0x00000100
CHR1=0x00FE007E, CHR2=0x00000000, CHR3=0x00000648, CHR4=0x00000000
CHR5=0x00000000, CHR6=0x00000000, CHR7=0x00000000, CHR8=0x00000000
CHR9=0x00000000, CHR10=0x0000182A
SDMA Registers:
SDC=0x00002201, SDCM=0x00000080
CRDP=0x0F844520, CTDP=0x0F846070, FTDB=0x0F846070
Main Routing Register=0x77077700 BRG Conf Register=0x00490018
Rx Clk Routing Register=0x00800088 Tx Clk Routing Register=0x00900010
GPP Registers:
Conf=0x53055600, Io=0x53055600, Data=0xFFFFFBFB, Level=0x00000800
TDM FPGA Registers:
vmcr[0] = 0x0003C0C0, vmcr[1] = 0x00000000,
vmcr[2] = 0x00010040, vmcr[3] = 0x00000000
ntrcr0 = 0x00000000, ntrcr1 = 0x00000000
tdmcr = 0x0000006A, labcr = 0x00000000, tpllr_cr = 0x00000000
nhr = 0x66646664, isr = 0x00000000, imr = 0x00000013
0 input aborts on receiving flag sequence
That leads to the cable being defective.
Thanks, thank you very much...
you all right I am testing my WIC by using Cisco router lab test cable my wic card is working so this leading cable problems but now I need to upgrade my wan link speed to 4mb/s and I have smart WIC witch cable can I use , I am really disappointment
Thanks for sharing, I am having a similar work to execute.
I need to change the serial cable for a Comtech modem CDM 570L to fit for a HWIC 2t interface, what changes did you make on the modem to accept the cable. My cable is CAB-SS-530MT.
