ISDN Backup - Help Needed
bradlesliect
I know we visited this before but I still have the problem. I have attached a diagram to illustrate my dilemme.
Basically we run OSPF between between Sites A and B. At Site A I have injected a static route from Router 1 to 2. The reason for this that the ISDN backup is on router 2.
What's happening at the moment is the ISDN backup keeps initialing for no apparent reason. Could it be OSPF related?
Check attachments for errors and diagram.
Config on Router 1:
ip route <network B> 255.255.255.0 <router1 IP> 240 name isdn-backup
On Router 2 I have a dialer configured and a route statement pointing to that dialer.
Here is config:
ip route <network B> 255.255.255.0 Dialer3 240 name isdn-backup
Config on Router 2
interface Dialer3
description <number>/site b-backup
ip address 192.168.225.21 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no ip split-horizon
shutdown
dialer pool 1
dialer remote-name cr17
dialer string <number>
dialer-group 1
no keepalive
no cdp enable
ppp authentication pap callin
ppp pap sent-username cr1 password removed
ppp multilink
ppp multilink links maximum 8
ppp multilink links minimum 4
ppp multilink load-threshold 75 either
ppp multilink endpoint hostname
max-reserved-bandwidth 90
end
router ospf 2
log-adjacency-changes
redistribute connected subnets
redistribute static subnets
network 192.168.225.0 0.0.0.255 area 0.0.0.0
access-list 130 deny eigrp any any
access-list 130 permit ospf any any
access-list 130 permit icmp any any
access-list 130 permit tcp any any
access-list 130 permit udp any any
access-list 180 permit icmp any any
dialer-list 1 protocol ip list 130
Config on Router 1
router ospf 2
17 Replies 17
smothuku
Level 7
Level 7
Hi ,
Can you change the config as below.
int dialer 3
dialer map 192.168.225.22 name < router 2> broadcast
config)# ip route < destination> 192.168.225.22 240.
config)# access-list 130 deny ospf any any
access-list 130 permit ip any any
OSPF routing packets are denied in the dialer-list.
and do the same thing on the other end.
In configuration you allowed ospf and applied it for dialer-list.Actually it should deny ospf.
IMP: remove redistibute static and connected commands configured under ospf.
satish
Will try what you suggested but will the ISDN activate when it needs to?
Satish,
You still online. I have a problem. The Site B has this config on the access-list.
sh run | inc access-list 130
access-list 130 remark user by dialer-list 1
The rest is the same, except for this.
Hi Brad ,
I have given example where eigrp is used as a routing protocol.In your case ospf is the routing protocol and u should deny ospf and permit any any.
As soon as ospf route vanishes folating static route comes in to the picture and isdn will be active.
When ospf comes back isdn will be deativated automatically...
whatever document i posted in the previous thread is an example.
Instead of eigrp put ospf and configure ity according to document.
If possible please paste the config of both router, i can do the mofdifications.
satish
Configure the following commands on both routers .i.e End-A router and End-B router.
end -A:
config)#dialer-list 1 protocol ip list 130
End-B:
config)# ip route < destination> 192.168.225.21 240.
config)# dialer-list 1 protocol ip list 130.
IMP:Before that remove all access-list and dialer-list 1 command from both the routers.
satish.
What you mean by
"IMP:Before that remove all access-list and dialer-list 1 command from both the routers."
You mean before I make the changes you recommend I need to remove the current access-list applied to the dailer-list 1?
Hi Satish,
This did not fix my problem. Look at the log from a debug dialer
126377: Feb 11 14:19:00.234 SAST: Se1/1:15 DDR: Dialing cause ip (s=192.168.225.21, d=224.0.0.5)
126378: Feb 11 14:19:00.234 SAST: Se1/1:15 DDR: Attempting to dial 0116212200
126379: Feb 11 14:19:02.230 SAST: %LINK-3-UPDOWN: Interface Serial1/1:30, changed state to up
126380: Feb 11 14:19:02.230 SAST: Se1/1:30: interface must be fifo queue, force fifo
126381: Feb 11 14:19:02.238 SAST: %DIALER-6-BIND: Interface Se1/1:30 bound to profile Di3
126382: Feb 11 14:19:02.238 SAST: %ISDN-6-CONNECT: Interface Serial1/1:30 is now connected to 0116212200 N/A
126383: Feb 11 14:19:03.294 SAST: %ISDN-6-DISCONNECT: Interface Serial1/1:30 disconnected from , call lasted 1 seconds
There is still something activating this dialer
smothuku
Level 7
Level 7
Hi ,
The below link shows how to configure isdn as a backup .
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_configuration_example09186a00800a3b77.shtml
Thaks,
satish
Thanks for the help on the config for the 2 sites. It worked. I still see something trying to activate ospf in access-list 130. How can I see who the culprit is? I see this on both sites A and B.
sh access-lists 130
Extended IP access list 130
10 deny eigrp any any
20 deny ospf any any (5 matches)
40 permit tcp any any
50 permit udp any any
Glad to hear that your problem is resolved.
You can check it with the help of show ip route when the isdn is active.
satish
If it wasn't for the deny ospf statement on the access-list the dialer would be connecting all the time.
sh access-lists 130
20 deny ospf any any (29448 matches)
30 permit icmp any any (345 matches)
40 permit tcp any any (992 matches)
50 permit udp any any (99 matches)
How do I debug these packets?
Hi Brad ,
we are denying the ospf using access-list because it prevent opsf packets from keeping the link up.
You can see what's happening with the packet using the following command.
debug ip packey detail.
Hope it helps you.
IMP: Don't use debug all or debug ip packet detail because router may go down after issuing the debug command due to high cpu utilization.
If you want to debug ip packet then use access-list in debug command as mentioned above.
satish
hey ...
you've been EXTREMELY helpful and VERY patient!
Thanks got the info. I got the source and destination addresses. It does make sense though.
208123: Feb 12 12:33:18.790 SAST: IP: tableid=0, s=ROUTER A IP (local), d=MONITORING SERVER (FastEthernet0/0), routed via FIB
208124: Feb 12 12:33:18.790 SAST: IP: tableid=0, s=ROUTER A IP (local), d=MONITORING SERVER IP (FastEthernet0/0), routed via FIB
208125: Feb 12 12:33:18.790 SAST: IP: tableid=0, s=ROUTER A IP (local), d=MONITORING SERVER IP (FastEthernet0/0), routed via FIB
208126: Feb 12 12:33:18.794 SAST: IP: tableid=0, s=ROUTER A IP (local), d=MONITORING SERVER IP (FastEthernet0/0), routed via FIB
208127: Feb 12 12:33:18.794 SAST: IP: tableid=0, s=ROUTER A IP (local), d=MONITORING SERVER IP (FastEthernet0/0), routed via FIB
208128: Feb 12 12:33:18.794 SAST: IP: tableid=0, s=ROUTER A IP (local), d=MONITORING SERVER IP (FastEthernet0/0), routed via FIB
208129: Feb 12 12:33:18.794 SAST: IP: tableid=0, s=ROUTER A IP (local), d=MONITORING SERVER IP (FastEthernet0/0), routed via FIB
208130: Feb 12 12:33:18.798 SAST: IP: tableid=0, s=ROUTER A IP (local), d=MONITORING SERVER IP (FastEthernet0/0), routed via FIB
208131: Feb 12 12:33:18.798 SAST: IP: tableid=0, s=ROUTER A IP (local), d=MONITORING SERVER IP (FastEthernet0/0), routed via FIB
208132: Feb 12 12:33:18.798 SAST: IP: tableid=0, s=ROUTER A IP (local), d=MONITORING SERVER IP (FastEthernet0/0), routed via FIB
Hi Brad ,
Thanks for your rating..
Netpro is very useful one...
Satish
