ISDN backup problem - really confused
sleste
Hi, I have an ISDN backup problem. Seems to me that everything is working with the ISDN backup dialer when it comes to the physical connection. When my GRE tunnel (using GRE tunnel due to other cirumstances which I will not go into now) goes down due to loss of connectivity, the dialer at the remote site C1712 router fires up the ISDN connection towards the other end, which is a C3660 router. My static routes then spring into action to make it possible to route to the 172.17.0.0/23 network via the ISDN link instead of the main link. The routing tables on both sides then contain routes to their reseptive dialers to route this traffic. However, when performing a ping, no response is received at all! I cannot seem to even ping the IP addresses on the dialer interfaces.
I have trimmed the configs from both routers to just include the necessary information (other interfaces have been removed, etc.).
Is there anyone who can spot where I have gone wrong with the config? ANY help would be greatly appreciated!! :o)
C1712 router:
hostname StokkeTest-router
isdn switch-type basic-net3
interface BRI0
no ip address
encapsulation ppp
no ip split-horizon
shutdown
dialer rotary-group 1
dialer-group 1
isdn point-to-point-setup
interface Tunnel0
ip address 172.17.62.10 255.255.255.252
backup delay 2 20
backup interface Dialer1
keepalive 5 2
tunnel source Loopback0
tunnel destination 172.17.62.1
interface Dialer1
description Backup Connection to Stokke
ip address 172.17.61.26 255.255.255.252
encapsulation ppp
dialer in-band
dialer idle-timeout 60
dialer map ip 172.17.61.25 name C3660_Skodje class dial1 broadcast 5551234
dialer-group 1
ppp authentication chap
ppp chap hostname StokkeTest-router
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0
ip route 172.17.0.0 255.255.254.0 Tunnel0
ip route 172.17.0.0 255.255.254.0 Dialer1 10
map-class dialer dial1
dialer-list 1 protocol ip permit
C3660 router:
hostname C3660_Skodje
username StokkeTest-router password 0 xxx
interface GigabitEthernet0/0
description connected to Ethernet Skodje
ip address 172.17.0.2 255.255.254.0
ip nat inside
duplex auto
speed auto
media-type rj45
negotiation auto
interface BRI3/0
description ISDN-backup
no ip address
encapsulation ppp
dialer pool-member 1
dialer pool-member 2
dialer pool-member 3
dialer pool-member 4
dialer pool-member 6
no cdp enable
interface BRI3/1
no ip address
interface BRI3/2
no ip address
interface BRI3/3
no ip address
interface Dialer6
description ISDN-backup Slyper Test
ip address 172.17.61.25 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer pool 6
dialer remote-name StokkeTest-router
dialer hold-queue 100
dialer-group 1
no cdp enable
ppp chap hostname C3660_Skodje
router eigrp 1
redistribute static
passive-interface GigabitEthernet0/0
network 10.0.0.0
network 172.17.0.0
auto-summary
neighbor 172.17.60.54 GigabitEthernet0/1
ip classless
ip route 172.17.90.0 255.255.255.0 Tunnel0
ip route 172.17.90.0 255.255.255.0 Dialer6 10
8 Replies 8
Richard Burts
The first thing that I notice is the shutdown command on the BRI on the 1712 router.
I also notice that there is no dial in-band on the dialer interface of the 3660.
I notice that while the 3660 does have a username configured which is for the 1712 there is not any username on the 1712 for the 3660. I do not know whether you cut that out accidentally in preparing the config for posting or whether it is really missing.
If none of these help your problem then it would be helpful if you would run some debugs and post the output. I would suggest debug isdn q931, then debug ppp negotiation, then debug ppp authentication. You can run these one at a time or run them together.
Rick
Rick
and thanx for replying to my post.
Firstly, when I put the "no shut" command under the BRI0 interface on the C1712 router, I constantly get this message at intervals:
StokkeTest-router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
StokkeTest-router(config)#int bri 0
StokkeTest-router(config-if)#no shut
*May 16 18:24:26.147: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
*May 16 18:24:26.147: %LINK-3-UPDOWN: Interface BRI0:2, changed state to down
*May 16 18:24:26.199: %LINK-3-UPDOWN: Interface BRI0, changed state to up
*May 16 18:24:26.215: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 97 changed to up
*May 16 18:24:41.295: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 97 changed to down
*May 16 18:24:41.327: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 97 changed to up
*May 16 18:24:56.395: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 97 changed to down
*May 16 18:24:56.427: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 97 changed to up
*May 16 18:25:11.491: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 97 changed to down
*May 16 18:25:11.527: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 97 changed to up
Is this normal?
Secondly, I did as you said in your post a bit too much cutting. This line is in the config for the C1712
username C3660_Skodje password 0 xxx
I will run the debug commands and post them here.
Steffen
Steffen
I would not think that the layer 2 going down and quickly back up, and repeating every 15 seconds is normal.
Seeing these messages I would suggest that you start with debug isdn q921 and then do debug isdn q931. I would wait for the debug ppp till there is resolution of the flapping down and up.
Rick
Rick
Hi again,
I enabled the debugs on the C1712 router as you stated in your reply.
When I disconnected the ethernet0 on the C1712 this is what happened:
*May 16 18:35:30.611: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 97 changed to down
*May 16 18:35:30.615: ISDN BR0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*May 16 18:35:30.643: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 97 changed to up
*May 16 18:35:35.207: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*May 16 18:35:40.207: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to down
*May 16 18:35:45.691: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 97 changed to down
*May 16 18:35:45.695: ISDN BR0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*May 16 18:35:45.727: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 97 changed to up
*May 16 18:35:46.207: %LINK-3-UPDOWN: Interface Dialer1, changed state to up
*May 16 18:36:00.795: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 97 changed to down
*May 16 18:36:00.795: ISDN BR0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*May 16 18:36:00.827: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 97 changed to up
*May 16 18:36:15.895: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 97 changed to down
*May 16 18:36:15.895: ISDN BR0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*May 16 18:36:15.927: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 97 changed to up
*May 16 18:36:30.995: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 97 changed to down
*May 16 18:36:30.995: ISDN BR0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*May 16 18:36:31.027: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 97 changed to up
*May 16 18:36:46.091: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 97 changed to down
*May 16 18:36:46.095: ISDN BR0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*May 16 18:36:46.127: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 97 changed to up
*May 16 18:36:52.883: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 97 changed to down
I still get the up and down on the LAYER2 as I stated in my last reply. Not sure why it would be doing this. Cable fault? Config fault?
Steffen
Steffen
I am not sure what causes this but I have two suggestions. First can you verify that the switch type you specify is correct according to the provider of the ISDN?
Second I notice that you are using this configuration command:
the documentation describes this as being for static TEI but I do not see that you have configured static TEI. I suggest that you remove isdn point-to-point-setup from the config and see if it makes any difference.
Rick
Rick
Rick
The flapping I seem to have solved with using another cable. I don't get the flapping messages on the LAYER2 anymore.
As for the switch type, I have looked it up and it's the correct one for my country -> Norway.
The new debug shows this after doing all the forementioned debug commands. I only get this result:
StokkeTest-router#debug isdn q921
debug isdn q921 is ON.
StokkeTest-router#debug isdn q931
debug isdn q931 is ON.
StokkeTest-router#debug ppp negotiation
PPP protocol negotiation debugging is on
StokkeTest-router#debug ppp authentication
PPP authentication debugging is on
StokkeTest-router#
*May 16 19:11:43.943: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*May 16 19:11:52.943: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to down
*May 16 19:11:58.943: %LINK-3-UPDOWN: Interface Dialer1, changed state to up
And that is about it. Am I missing anything? I would think that the debug would create more feedback? After Dialer1 went up I waited for several minutes, but didn't receive any more debug feedback.
Will be removing the ISDN Point-Point commands now and try again...
Steffen
Steffen
I am glad that you fixed the flapping issue with a different cable.
Yes I would expect more output from the debug. It seems to me that either there is some problem with your logging including debug output (but it did get debug output in the previous post where you were running debug isdn q931). Or that the dialer is not doing anything. To verify whether it is doing anything you can run debug dialer.
I will be very interested whether removing the point to point setup command changes anything. (I am not sure that it will, but I think the command is worth removing since it seems to be intended for an environment different from what you are running)
Rick
Rick
Hi to all who were kind enough to reply,
the problem was fixed last week. There was something wrong with the ISDN connections on the other end. It all seemed to work fine, as I saw the dialer on the other side getting the connection, but it newer routed any traffic. Exactly what was wrong I will never know, but it was definitely something on the ISDN layer. I got a technician from the phone company who set up the ISDN connections for the clients. The ISDNs went through some sort of phone central, so not your basic run-of-the-mill sort of ISDN. At least noe here in my country. The technician called back saying he had tested everything, but made no changes. After saying so, everything worked like a charm. Funny and pretty miraculous, huh?! :) So, my solution must have been that the technician from the phone company really did some changes (as a collegue of mine who was on-site when it happened, said the guy was going through tons of parameters on the phone system), or that the ISDN cables where not totally attached or something in that order? I believe the first to be true, as I had my collegue try out the ISDN points with his laptop and an ISDN card with which he was dialing up and Internet connection. He got connected, but had problems sending and retreiving data.
To be honest, it's not the first time I have had a problem solved miraculously while another technician was going over things and "not doing any changes". :)
In any case, I am happy things are working and so is the client.
Again thanx for all the replies to my thread.
Steffen
