ISDN configuration: PPP multilink and dialer load-threshold
Wassim Aouadi
Level 4
Level 4
hi,
I'm getting confused while trying to understand the relationship between PPP Multilink, dialer load-threshold and dialer idle-timeout here.
here's the DDR dialer profile configuration :
interface Dialer200
description **** Dialer SSE 1 ****
ip address 192.168.200.9 255.255.255.252
encapsulation ppp
dialer pool 200
dialer remote-name yyy
dialer idle-timeout 60 either
dialer string 77801001
dialer load-threshold 1 inbound
dialer-group 1
no fair-queue
ppp authentication chap callin
ppp chap hostname xxx
ppp chap password zzz
ppp multilink
anyone could give me an explanation?
Forum Tips: 1. Paste images inline - don't attach. 2. If you find my post helpful, please give it a thumbs up or mark it as a correct solution; You never know in the future who you might help doing so..
Giuseppe Larosa
Hello Wassim,
PPP multilink in ISDN scenario means using multiple bearer B channels as needed and as many as they are available on the physical interfaces BRI or PRI associated with the pool 200.
dialer load-threshold 1 inbound says the router to add additional B channel(s) as soon as the call is setup, because usage of 1 is the minimum (it is expressed as 1-255 with 255 meaning full loaded)
means that the time the call is held up without seeing any interesting packet on the link to be tramsmitted or received (either) is 60 seconds
The interesting traffic that can trigger the call and that is checked to decide if keeping up the call is defined by
dialer-group 1
tha points to dialer-list 1
Hope to help
Giuseppe
hi Giuseppe,
About the "dialer load-threshold" in a PPP multilink context, I found the following in Dial Technology Reference Guide:
"When multilink PPP is configured, the dialer load-threshold 1 command no longer keeps a multilink bundle of n links connected indefinitely"
so I guess "dialer load-threshold 1 inbound" has a special meaning here?
Hello Wassim,
inbound = received
but I'm not sure if in this case what will be the effect if this is enough to revert to old behaviour.
I've gone to 12.4 Dial reference
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_d1.html#wp1013318
read it carefully it looks like that only using an high idle-timeout you can keep up multiple B channels.
The reason are the bills to be payed: customers have asked Cisco to change the behaviour to reduce expenses in countries with no flat rate (for example in Germany ISDN is flat rate)
Hope to help
Giuseppe
