ISDN Dial Backup Bundled with Serial Interface
gary00001
Hi All
I have a problem where i have a 512k serial line from a branch Office into my core. I have applied for additional bandwidth but can only get it later in the year due to Telco problems.
I have a PRI used for dial backup and dialin users, can i get the isdn to dial up and bundle with my primary link when a threshold is reached.
7 Replies 7
attrgautam
Level 5
Level 5
Yes it is possible though performance wil be hit. You can use backup interface and backup load threshold which will trigger the backup when the threshold configured is reached.
I have done that, it seems to acknowledge the fact that the interface needs to come up but it does not dial the interface up
hi
Can you post the config of your router here (with public ips and passwds masked )?
regds
interface Serial1/0:1
description lancet-jhb
mtu 600
bandwidth 512
backup interface Dialer1
backup load 20 10
ip address (ip address)
encapsulation ppp
ip mroute-cache
load-interval 30
no fair-queue
down-when-looped
no cdp enable
ppp multilink
interface Dialer1
description ISDN Dialup/Backup
no ip address
encapsulation ppp
dialer in-band
dialer idle-timeout 900
dialer string 70113580980
dialer-group 1
no peer default ip address
no fair-queue
no cdp enable
ppp authentication chap
ppp chap hostname PILLMAC
ppp chap password 7 ##############
ppp multilink
1) Wonder why you need the multilink on the serial
2) Can you show the routes in the router ? The Route to Dialer should be of the same AD as the route to the Serial. THen it will dial out
i accidently left it on i was going to put ppp multilink on the interface for Interleaving
ip route 172.16.0.0 255.255.0.0 192.168.2.5 100 - Serial
ip route 172.16.0.0 255.255.0.0 192.168.3.1 200 - Dialer
Should i have an ip address on my Dialer Interface or unnumbered
I would suggest using the ip unnumbered if you are getting a static IP on the dialer. That is the reason why i think it isnt dialing out.
