ISDN Dialer Test Call .??????
afzaalq007
I want to Test a call from My ISDN Bri interface i have avialbe ISDN pair to chk it
Physically i have made it and now want to config it Just dial an other Isdn Number ????
How I do it ????
My config ... are will it Work ????
nterface Dialer0
no ip address
no ip directed-broadcast
encapsulation ppp
dialer remote-name XXXXX
dialer idle-timeout 300
dialer string 0514409244
dialer pool 1
ppp authentication chap
CCampbell_2
If you simply want to test the BRI interface, I would just use the 'isdn test call' command. It's available in privileged exec mode.
If you want to do it with the dialer interface you're going to need a static route that points out the Dialer0 interface before an outdial will be made.
Cliff
Thanks for the Ans
i am using the currently this
IOS (tm) 2500 Software (C2500-IS-L), Version 12.0(3)
and I have chek the ISDN test Call command it s not avialble ..
Can you tell me in little bit detail the other method
ndarnell
Put an ip address from the same subnet (/30 would work well) on each end and then ping the remote end. This will then initiate the dialer
N
