ISDN not working
imran.moulvi
Hi Experts,
I have a trouble with an ISDN conenction at one of our sites in US.
We have a Verizon provided ISDN and the switch type is 5ESS.
Verizon doesnt see our SPIDs and we have programmed the SPIDs correctly as they mentioned.
Please see below the output of sh isdn status & sh run int bri0/2/0.
router#sh run int bri0/2/0
Building configuration...
Current configuration : 396 bytes
interface BRI0/2/0
ip address x.x.x.x 255.255.255.0
encapsulation ppp
dialer idle-timeout 600
dialer map ip y.y.y.y name wci01a broadcast <no taken off>
dialer load-threshold 100 outbound
dialer-group 1
isdn switch-type basic-5ess
isdn point-to-point-setup
isdn spid1 016940329000
isdn spid2 016947195000
isdn T203 10000
no fair-queue
no cdp enable
ppp authentication chap
end
router#sh isdn status
Global ISDN Switchtype = basic-5ess
ISDN BRI0/2/0 interface
dsl 4, interface ISDN Switchtype = basic-5ess
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 112, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI 112, ces = 1, state = 4(await init)
spid1 configured, no LDN, spid1 sent, spid1 NOT valid
TEI Not Assigned, ces = 2, state = 1(terminal down)
spid2 configured, no LDN, spid2 NOT sent, spid2 NOT valid
Layer 3 Status:
0 Active Layer 3 Call(s)
CCB:callid=0, sapi=0, ces=1, B-chan=0, calltype=INTERNAL (BR0/2/0) SPC Call
Active dsl 4 CCBs = 1
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 1
Can someone please help.
Thank You,
Imran.
Giuseppe Larosa
Hello Imran,
check with your provider currently it is not ok
or the spids are wrong or they are not needed
"Currently, only the DMS-100 and NI switch "
types require SPIDs.
The AT&T 5ESS switch type may support a SPID, but we recommend that you set up that ISDN service without SPIDs. In addition, SPIDs have significance at the local access ISDN interface only. Remote routers never receive the SPID.
A SPID is usually a seven-digit telephone number with some optional numbers. However, service providers may use different numbering schemes. For the DMS-100 switch type, two SPIDs are assigned, one for each B channel."
see
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_cfg_isdn_bri_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1015900
Hope to help
Giuseppe
