ISDN PRI interface name
lifebook567
Is there an interface called pri0 like bri0 interface? Or PRI ISDN will be call "t0"
spremkumar
Level 9
Level 9
AFAIK we don't have any interface which can be displayed by using the keyword t0.
Though i am not sure you may use the same to see the details of an token ring interface which needs to be rechecked..
usually we do configure the controller interface either T1 PRI or E1 PRI in case of PRI.
regds
desai.jaideep
Level 5
Level 5
An PRI interface will be called :
controller e1
or
controller t1
JD
