ISDN PRI Voice Capable
oinojosa12
Which of the following ISDN PRI interfaces are capable for both voice and data:
NM-1CE1T1-PRI
HWIC-2CE1T1-PRI
VWIC2-2MFT-T1/E1
It would be installed on an 2801 router.
2 Accepted Solutions
slmansfield
Level 4
Level 4
If I am not mistaken, of the three options only the VWIC is supported on the 2801. It is voice and data capable.
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
The VWIC supports ISDN for voice.
Remember you will also need PVDM2-xx.
No voice configuration can be done without it.
slmansfield
Level 4
Level 4
I have read that data sheet already, but I do not see any clear mention about ISDN.
You may need additional memory depending on how many modems you want. When I used the Dynamic Configuration tool I got this message:
Please refer to the DSP Calculator at the following URL to make sure you have selected enough PVDM resources: http://cisco-images.test.edgekey.net/cgi-bin/Support/DSP/dsp-calc.pl. Note, Cisco 2801 supports maximum 30 digital voice calls with VWICs.
