isdn2 x 4
Danilo Dy
Is there a way or is it possible to bind 4 x isdn2 together? All terminates in the same router in both sites (A & B).
Just curius, I saw a written solution that says 512Kbps isdn2
Dandy
paolo bevilacqua
Yes, with the physical interfaces controlled by single dialer interface, with the thresholds configured, it will setup and teardown channels as traffic load requires.
paolo bevilacqua
Hi Paolo,
I thought of putting the 4 bri interface into one dialer pool-member and one dialer interface for that dialer pool. My skepticism is that each isdn2 circuit has a dialer string, won't it be a problem?
I'm still digging for docs in Cisco website :)
EDIT: Ok, I understand it know.
Dandy
