09-24-2013 04:12 AM - edited 03-04-2019 09:07 PM
Hi Guys,
I know that level 2 routers learn about paths both within areas and between areas.
If that is so , can we repeat the vlans that are in area 1 to the area2 ,i.e excluding the vlans that are directly connected.
09-24-2013 04:27 AM
I believe you are confusing two things together. To a routing protocol, a VLAN is a Layer2 technology just like any other interface, be it Token Ring, PPP, ATM, Frame Relay, etc. Just like a router's interface terminates a particular Layer2 technology on the router and does not allow it to transparently pass further, a router also terminates a VLAN without allowing it to pass further. So regardless of IS-IS, its levels and areas, VLAN numbers on different interfaces of routers can be reused, even on a single router. So for example, this configuration is perfectly valid:
interface FastEthernet0/0
no shutdown
interface FastEthernet0/0.10
encapsulation dot1q 10
ip address 10.0.10.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1q 20
ip address 10.0.20.1 255.255.255.0
interface FasthEthernet0/1
no shutdown
interface FastEthernet0/1.10
ip address 10.1.10.1 255.255.255.0
interface FastEthernet0/1.20
ip address 10.1.20.1 255.255.255.0
What can not be reused are the IP address spaces - they have to be unique across the entire routed internetwork, regardless on their placement in areas or Layer2 technologies.
Please feel welcome to ask further!
Best regards,
Peter
09-27-2013 12:39 AM
Hi All,
Thanks Peter for the clarification.
The topology is like the attach, we have to terminate mpls pseudowire
from DX to the 2 AX,i.e AX1 & AX2 over this ISIS network;
could it be possible like as mentioned in diagram.
Kumar
