ATM interface issues
abukuru95
Level 3
Level 3
Hi Guyz,
I am having a very strange issue with my 887 Branch router type at different locations that suddenly loose connection on the WAN ATM0 interface.
A router reboot does not solve help bring up the interface but when the ATM0 cable connection is unplugged and plugged in again, it works.
Does anyone have a hit as to what this could be? I am experiencing it more and more often.
see below for the device details.
IOS
c880data-universalk9-mz.150-1.M3.bin"
TYPE
CISCO887-SEC-K9
ATM0 is up, line protocol is up
  Hardware is MPC ATMSAR (with Alcatel ADSL Module), address is 1cdf.0f07.ff10 (bia 1cdf.0f07.ff10)
  MTU 4470 bytes, sub MTU 4470, BW 512 Kbit/sec, DLY 720 usec,
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  20 maximum active VCs, 1024 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/224/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Per VC Queueing
  30 second input rate 3000 bits/sec, 4 packets/sec
  30 second output rate 4000 bits/sec, 3 packets/sec
     32175 packets input, 10623248 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     35056 packets output, 9231789 bytes, 0 underruns
     0 unknown protocol drops
thanks in advance.
paolo bevilacqua
Update IOS or DSL firmware.
paolo bevilacqua
Well, what puzzles me is why this is happening all over a sudden on different devices.
I thought more of a configuration change on the provider ATM cloud that i am also trying to investigate at the moment.
thanks.
will keep u posted.
