Isis Metric
Dears the metric RIP IS hop-count, but what IS the metric from ISISI? It seems   10, but im not sure!
Reza Sharifi
yes, default is 10
The Integrated IS-IS Global Default Metric feature  allows you to use one command to change the metric value globally for  all IS-IS interfaces. Besides offering the user the convenience of being  able to globally configure the value for all IS-IS interfaces, the  feature helps prevent errors that occur when interfaces are individually  configured to change the metric value: user can remove metrics from an  interface and then add the interface back into IS-IS without a set  metric, thereby allowing the default metric 10—unintentionally making  that interface a highly preferred one in the network. Such an occurrence  on the wrong interface could mean the rerouting of traffic across the  network on an undesirable path.
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gtisglob.html#wp1027177
Thanks, and what is metric from BGP?
If you are looking for BGP MED, that is 0 by default.
