Showing results forĀ
Search instead forĀ
Did you mean:Ā
Install HWIC-1GE-SFP on 3845 Router
Hi All,
In our Environmet we have 3845 Edge Router Current Ios Version is  Version 12.4(1a),(c3845-advipservicesk9-mz.124-1a.bin)
As management got another fiber leased line(Single Mode) for which i have install SFP slot part number  HWIC-1GE-SFP,
after installation of HWIC-1GE-SFP in router the follwing slot is showing
GigabitEthernet0/1/0
%HWIC_1GE_SFP-6-SFP_IN: Interface GigabitEthernet0/1/0 1000BaseLX SFP has been  inserted
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/1/0       xx.xx.xx.xx.      YES manual up                    down
for testing purpose i tried the same procedure into the switch and its working fine where as in Router the link is not coming up ,
any help will be appriciated
Thanks in advance,
5 Replies 5
dumesh
Hi Aman,
Will a shut and no shut put the interface in up/up state?
CSCsf31178 matches your symptoms. Fixed in 12.4(03g),12.4(08c),          12.4(07d) and above in the mainline version.
You may try upgrading the IOS to one of the latest mainline IOS release.
Hope it helps. If it doesn't, could you copy paste the interface configuration from both ends?
Cheers,
Dheeraj
Leo Laohoo
Try rebooting the router.
Hi Dheraj, Leolaohoo,
Thanks for your Reply
I tried to reboot the Router and also tried to Shut and no shut for the interface , do i need to install the firmware
Cisco 1-Port DOCSIS-based Cable High-speed WAN Interface Card (HWIC) for this card or need to upgrade the existing Ios
have u connected any device to this port???
if yes then please check the setting for dplex and speed on both side.
If you pase the config of both side ports then we can easily troubleshoot it.
REgards
Please rate if it helps.
Thanks for your reply
First i install the New HWIC-1GE-SFP card on 3845 router after that i connect the GLC (SFP) ,The below  configuration i got from my service provider after i did this configuration
The out put is here  i reload the router several times  and did the shut/no shut as per your request the below is the output  , suggest me whether we  need to replace the new HWIC-1GE-SFP Card  and check  the status or upgrade the IOS , we have only one Router , and its in production
interface GigabitEthernet0/0/0
no ip address
no negotiation auto(if i  put the negotiation auto then also its not coming )
interface GigabitEthernet0/0/0.897
encapsulation dot1Q 897
ip address xx.xx.xx.230 255.255.255.252
no snmp trap link-status
router bgp xxxxx
no synchronization
bgp log-neighbor-changes
neighbor xx.xx.xx.229 remote-as xxxx
no auto-summary
xxxxxxxx#sh interfaces gigabitEthernet 0/0/0
GigabitEthernet0/0/0 is up, line protocol is down
  Hardware is PM-3387, address is xxx.xxxx.22f3 (bia 0xx.xxxx.22f3)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is force-up, media type is LX
  output flow-control is XON, input flow-control is XON
  Last input never, output 00:00:05, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 0 pause input
     3213 packets output, 193676 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     0 lost carrier, 0 no carrier, 0 pause output
XXXXXX#sh interfaces gigabitEthernet 0/0/0.897
GigabitEthernet0/0/0.897 is up, line protocol is down
  Hardware is PM-3387, address is xx.xxx.22f3 (bia xx.xxx.22f3)
  Internet address is xx.xx.xx.230/30
  Encapsulation 802.1Q Virtual LAN, Vlan ID  897.
XXXXXXXXX#
