ISP NAT / ARP Issue
jonathanw84
We have a 1941 that we use at a residence with a Frontier FIOS circuit. They provide us with 5 static IPs and we NAT different internal networks to each of the addresses - a pretty standard config. As of a week ago, this stopped working with the exception of the main IP. The ISP says there is nothing on their end that is wrong, but nothing has changed on our end and this has been working for around 6 months. We are also seeing entries in the arp table that show the ISP as the hardware address:
Internet X.X.X.1 -   204e.71c5.31c8 ARPA GigabitEthernet0/1
Internet X.X.X.37 - c47d.4f75.21e1 ARPA GigabitEthernet0/1
Internet X.X.X.38 - 204e.71c5.31c8 ARPA GigabitEthernet0/1
Internet X.X.X.39 - 204e.71c5.31c8 ARPA GigabitEthernet0/1
I have tried doing a static arp entry with no success as well. It's a very standard and simple configuration and while I think it's an ISP issue (perhaps they enabled proxy-arp or something like that), I wanted to check here as well. Thanks!
Relevant Configuration:
interface GigabitEthernet0/1
bandwidth 100000
ip address X.X.X.37 255.255.255.0
ip nat outside
ip virtual-reassembly in
zone-member security OUTSIDE
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 X.X.X.1
ip nat pool GUEST X.X.X.39 X.X.X.39 netmask 255.255.255.0
ip nat pool CAMERAS X.X.X.38 X.X.X.38 netmask 255.255.255.0
ip nat inside source route-map CAMERAS pool CAMERAS overload
ip nat inside source route-map GUEST pool GUEST overload
ip nat inside source route-map INTERNAL interface GigabitEthernet0/1 overload
route-map INTERNAL permit 10
match ip address NETWORKS_INTERNAL
match interface GigabitEthernet0/1
route-map CAMERAS permit 10
match ip address NETWORKS_CAMERAS
route-map GUEST permit 10
match ip address NETWORKS_GUEST
16 Replies 16
Hi Paul! Thanks for the response.
I would go off the configuration I posted in my last post:
ip nat pool INTERNAL X.X.X.40 X.X.X.40 netmask 255.255.255.0
ip nat inside source route-map INTERNAL pool INTERNAL overload
ip nat inside source list NETWORKS_NAT interface Cellular0/1/0 overload (used for cellular backup)
That is where we were at before things miraculously stopped working a few weeks ago and where we want to be.
With regard to the ZBF, the ACLs are there I just must have omitted them from the configuration. Either way, this has been a working configuration for years so I don't suspect any issues with the ZBF because I can definitely get this working for a while and then it stops after a short time. Good points with the CAMERA / DMZ zones though! I will consolidate those.
Another update is that it definitely has nothing to do with the cellular back up I mentioned in the last post as it seems as if the ISP is only allowing one address at a time and blocking the rest, even though we pay for a block of addresses. We had a high SLA DIA circuit with a block before and this worked fine for years. We then moved to a Frontier FiOS line with an address block about 6 months ago and this has been working up until a few weeks ago. I've worked with them tirelessly for weeks but they keep coming back saying it's my equipment. I don't think that's correct though and definitely think it's an ISP issue. We have the 1941 connected directly to the ONT box via copper (so no router in between).
Hello
If you have scope to test, try domainless nat instead just to see if this makes any difference.
Nat interfaces
int x/x
no ip nat inside or outside
ip nat enable
no ip nat inside source route-map CAMERAS pool CAMERAS overload
no ip nat inside source route-map GUEST pool GUEST overload
no nat inside source route-map INTERNAL pool INTERNAL overload
no ip nat inside source list NETWORKS_NAT interface Cellular0/1/0 overload (used for cellular backup)
ip nat source route-map CAMERAS pool CAMERAS overload
ip nat source route-map GUEST pool GUEST overload
ip nat source route-map INTERNAL pool INTERNAL overload
ip nat source list NETWORKS_NAT interface Cellular0/1/0 overload (used for cellular backup)
Kind Regards
Paul
