01-05-2022
11:45 AM
- last edited on
01-07-2022
02:15 AM
by
Translator
Hi, I have large trouble I forgot password and trying to hard reset and following all over console but it does not work.
I turned off router, pressed reset button and keeped it 10s until leds off but after that system said:
Rom image verified correctly
System Bootstrap, Version 16.9(1r), RELEASE SOFTWARE
Copyright (c) 1994-2018 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerOn
C1111-8PWE platform with 4194304 Kbytes of main memory
Reset button push detected
unable to open bootflash:golden.bin (14)
no valid BOOT image found
Final autoboot attempt from default boot device...
Located c1100-universalk9_ias.16.09.05.SPA.bin
and after that again get asking for login from asme crediternal nothing is reseted.
Solved! Go to Solution.
01-06-2022 11:23 PM
Reset button push detected unable to open bootflash:golden.bin (14) ........ no valid BOOT image found Final autoboot attempt from default boot device... Located c1100-universalk9_ias.16.09.05.SPA.bin
Looks you have boot image issue of boot parameter here.
post complete boot process to suggest or advise better.
01-05-2022 11:56 AM
have you tried the BREAK key ? You should get a prompt asking you if you want to reset the router to factory defaults. Press BREAK (or Ctrl+Break) within 10 seconds after restarting the router. You need to console into the device (using Putty or HyperTerminal).
01-05-2022
12:27 PM
- last edited on
01-07-2022
02:22 AM
by
Translator
when do it I got
\\\\ nad system continue booting
like this
\\\\Rom image verified correctly
ctrl and brake nothing happend
01-05-2022 12:43 PM
01-05-2022 03:08 PM
Got unvalid characters in that combination of modulation.
Before hyper term I used Putty.
Maby to test over native pc and direct connection to cisco, but my usb to serial working well.
01-05-2022 01:25 PM
Hello
You then need to power down the rtr once more before you are able to access the router with default settings,
01-05-2022 03:09 PM
My router is off, evry time test it over trurnin it on from start. It is not usefull now without access
01-05-2022 03:48 PM
What need to try to do CTRL+Brake or only brake.
Will try on native over windows 7 and old pc over native com port.
01-06-2022 11:23 PM
01-07-2022 09:44 AM
just out of curiosity, how did you resolve this ?
01-07-2022 09:50 AM
01-07-2022 09:53 AM
sorry for the misunderstanding, but is the issue resolved, or not ? If you mark a question as resolved, usually people assume that it actually IS resolved, and won't look at the thread anymore.
01-07-2022 09:56 AM
01-07-2022 10:22 AM
no problem, but marking a question as resolved will accomplish exactly the opposite: you won't get help anymore because people assume that the issue has been resolved.
When you boot the router, just keep pressing Ctrl+Break, for up to 60 seconds. You need to get into ROMMON no matter what.
01-07-2022 10:25 AM
