ISR 1111-8p multicast over Bridge domain
Kalin Hristov
Hello, guys
Do you know if multicast traffic is supported with bridge domains on ISR 1100
My config is pretty simple:
interface GigabitEthernet0/0/0
no ip address
load-interval 30
negotiation auto
service instance 777 ethernet
encapsulation dot1q 777
rewrite ingress tag pop 1 symmetric
interface Vlan777
no ip address
bridge-domain 777
ip igmp snooping querier version 3
ip igmp snooping querier address 192.168.10.1
member GigabitEthernet0/0/0 service-instance 777
member Vlan777 service-instance 777
Unicast traffic works without any problems but multicast does not flow. I tried disable IGMP snooping without any success. I also tried without popping vlans, again unicast works without problems but multicast traffic is not seen in the remote device.
So do you know if this is supported in this platform?
Thank You
Kalin Hristov
To follow up to this problem. I have connected the WAN port belonging to the Bridge domain to a switch and started a SPAN session. IGMP packets are not flooded via this interface. All other traffic works fine, I even see PIMv2 Hellos from the neighboring router, but IGMP packets are not flooded so maybe this is a bug for this particular model.
