ISR 1111 + SQUID
skulikov944
Hello team.
I really want to understand and configure proxying certain sites through my VPS in another country, but unfortunately I am failing.
I have a cisco router 1100 series and vps + squid.
I have tried a large number of configurations in this regard using wccp and pbr
Can someone suggest a working config on the router side using PBR and squid
I have tried this config on router:
Spoiler
ip access-list extended PROXY-ACL
permit tcp any host <vps-ip-address> eq 80
permit tcp any host <vps-ip-address> eq 443
ip access-list extended BYPASS-ACL
deny ip any host <vps-ip-address>
permit ip any any any
route-map TRAFFIC-RMAP permit 10
match ip address BYPASS-ACL
set ip next-hop <next-hop-ip-address-to-gateway-my-isp>
route-map TRAFFIC-RMAP permit 20
match ip address PROXY-ACL
set ip next-hop <squid-ip-address>
interface <inside-interface>
ip nat inside
interface GigabitEthernet0/0/0
description ISP1
ip address dhcp
ip nat outside
ip policy route-map TRAFFIC-RMAP
ip nat inside source list PROXY-ACL interface gi0/0/0 overload
ip route 0.0.0.0.0.0 <next-hop-ip-address>
When I use this command on interface gi0/0/0, ip policy route-map TRAFFIC-RMAP I lose internet.
Config for squid:
Spoiler
http_port 3128
acl localnet src 10.10.0.1/24
acl SSL_ports port 443
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 # https
acl Safe_ports port 70 # gopher
acl Safe_ports port 210 # wais
acl Safe_ports port 1025-65535 # unregistered ports
acl CONNECT method CONNECT
http_access allow manager localhost
http_access deny manager
http_access deny !Safe_ports
http_access deny CONNECT !SSL_ports
http_access allow localhost
http_access allow localnet
http_access deny all
http_port MY_PUB_IP_VPS:8080 intercept
acl proxy_domains dstdomain "/etc/squid/proxy_domains"
acl proxy_sites dstdomain "/etc/squid/proxy_sites"
http_access allow proxy_domains proxy_sites
11 Replies 11
ip policy route-map TRAFFIC-RMAP <<- apply this command under LAN interface
ip nat inside
Just applied this policy to the vlan, the pages of sites I check just take a long time to load and show an error that "cannot open this page".
I think I made a mistake somewhere, but I can't figure it out. What I need to change?
Now my config loks like this:
Spoiler
10 permit tcp any host 90.90.90.90 eq www
20 permit tcp any host 90.90.90.90 eq 443
deny ip any host 90.90.90.90
permit ip any any
set ip next-hop 130.130.130.1
set ip next-hop 90.90.90.90
interface Vlan10
description WIRED
ip address 10.1.100.254 255.255.255.0
ip nat inside
ip virtual-reassembly
description ISP1
ip address dhcp
ip nat outside
negotiation auto
no cdp enable
We use PBR when we have multi-input point and TWO output Point
here I see only one interface connect to SP g0/0/0 so why PBR ?
and if there is other WAN interface you must config NAT to be aware about the next-hop of traffic.
There is no other wan channel, I thought this problem is solved only with PBR or WCCP.
If I have one wan channel, a couple of vlan and a squid server on the remote side, what can help me solve this problem?
what problem which you think will be solve by PBR ?
Initially, I planned to proxy certain subnets based on PBR, on which external sites hang in the direction of squid. Some solutions on the Internet describe such a scenario, but the information is vague, so I decided to experiment and sketched such a conf.
Hmmm, that need some kind of deep think.
I will update you soon
Sure! Thx a lot
skulikov944
Hi, I just wanted to ask how it's going. Did any of the options work out?
balaji.bandi
Couple of things need clarification :
1. how is your network diagram  - show us how Router and Squid proxy and users Lan connected ?
2. you have localnet 10.10.0.1/24  ?  (which i do not see on your Router config ?) Squid only allow these subnet source come from ? if any source coming from will be denied from squid.
3. are you looking to Lan side redirect traffic to proxy, or After nat Outside ?
BB
Of course, I have this kind of scheme.
Let's say there are two countries, one is ISR 1111 and the other is SQUID.
I need to make it so that when certain sites are requested, the traffic goes exactly to country 2 and out through Squid.
I also want to ask, is there any way to make it work for only certain sites?
I know I can configure the IPSEC tunnel and put the networks I need on it to make the traffic from those networks go to the squid, but I need to know which sites have which subnets and domain names to ask the system to send me to the squid.
