Redistributing connected secondary ip
bijay.swain
Hi All
Below is the config of a device running RIP
interface Vlan10
ip address 10.4.4.40 255.0.0.0
interface Vlan4
ip address 192.183.12.1 255.255.254.0 secondary
ip address 192.183.74.1 255.255.255.0
router rip
redistribute connected
network 10.0.0.0
My Question is this device is advertising the
192.183.74.0
network via RIP but why it is not advertising the
192.183.12.0
network .
RIPv1 and RIPv2 support redistribute connected
the issue is RIPv2 is classless which can advertise the two prefix
RIPv1 is classful which will advertise only one prefix
the issue is RIPv1 see one prefix not two
you can use different class for secondary IP and check again.
5 Replies 5
bijay.swain
RIP version 2 did solved .now it is advertising the
192.183.12.0/23
network through rip but another question comes as why it was not able to advertise
192.183.12.0 using /24
mask which is class C default .
RIPv1 being a very old protocol likely didn't support that feature. OSPF does by default I believe.
I agree with @David Ruess that RIPv1 is strictly classful in its approach to routing. It would regard
as invalid (based on the /23 mask) and would not advertise it. RIPv2 relaxes the classful requirements, recognizes the /23 as valid, and advertises the network.
Rick
Hi MHM
Thanks for your reply.
I tested with different class  and it did advertised it with default mask
