ISR 1921 Port Forwarding issue
JUNHOLEE95720
Hello.
We have configured port forwarding and it works fine.
1. Port forwarding from the external Internet to the internal server, OK
2. Port forwarding from the external Internet to the domain address of the internal server, OK
3. Access to the internal server from the internal Internet, OK
4. Inaccessible to the domain address of the internal server from the internal Internet
That is, the current problem is number 4.
There seems to be a command to put something in the router, but I do not know what it is.
router#show running-config
Building configuration...
Current configuration : 4198 bytes
! Last configuration change at 01:27:33 UTC Mon Sep 14 2020 by cisco
version 15.4
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip dhcp excluded-address 192.168.1.200
ip dhcp excluded-address 192.168.1.201
ip dhcp excluded-address 192.168.1.202
ip dhcp excluded-address 192.168.1.14
ip dhcp excluded-address 192.168.1.99
ip dhcp pool DHCP
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.254
 dns-server 85.93.5.142 8.8.4.4
 lease 0 1
ip cef
no ipv6 cef
cts logging verbose
crypto pki trustpoint TP-self-signed-1146144679
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1146144679
 revocation-check none
 rsakeypair TP-self-signed-1146144679
crypto pki certificate chain TP-self-signed-1146144679
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31313436 31343436 3739301E 170D3136 30393230 30383535
  32335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 31343631
  34343637 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B2CC 4A2B2D60 31B13776 7009B6B4 4A4C08DE 6CAE5554 777C9FED B38EEA4F
  DC2A4676 5F709759 8B510898 2640F781 FBC92B04 4B08AA91 80DFAC93 0CD615DC
  9AF73B11 F3DBF04C 5DA2CF53 E0DE5943 2D0462D0 E60FDAA0 0A00B104 6886E5C4
  C9EBF08A FDD92EFE F9E95EDC 8B1BB295 5FEEE3EB DDC43DC7 05C0F8BB 63C98CF6
  88670203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14F365BF 293FE4A7 FF8BC359 2D60B9C5 2F0C18B8 B9301D06
  03551D0E 04160414 F365BF29 3FE4A7FF 8BC3592D 60B9C52F 0C18B8B9 300D0609
  2A864886 F70D0101 05050003 818100A0 0280932D BBEB37FB BEEF219D E1ED0030
  39A2E73D A754F040 8F2099B0 3B8DFC6D 7E110F1D E35150BD 4C069382 F57A3681
  5919CF07 AB19E614 21494430 7B5EABD4 C82DD03F F161C4A1 B10C47A0 3A691667
  1E280B2E 20CDE150 2C7FD344 39236C18 EE33C1C0 A39C5BF6 A018EFC0 9BA1AFD3
  EF606476 6F05A484 A6728BA1 BFA2C8
        quit
license udi pid CISCO1921/K9 sn FGL203920YG
username cisco privilege 15 password 0 cisco
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 192.168.1.254 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.1.14 21 interface GigabitEthernet0/0 21
ip nat inside source static udp 192.168.1.14 21 interface GigabitEthernet0/0 21
ip nat inside source static tcp 192.168.1.14 20 interface GigabitEthernet0/0 20
ip nat inside source static udp 192.168.1.14 20 interface GigabitEthernet0/0 20
ip nat inside source static tcp 192.168.1.14 3307 interface GigabitEthernet0/0 3307
ip nat inside source static udp 192.168.1.14 3307 interface GigabitEthernet0/0 3307
ip nat inside source static tcp 192.168.1.14 5000 interface GigabitEthernet0/0 80
ip nat inside source static udp 192.168.1.14 5000 interface GigabitEthernet0/0 80
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
control-plane
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 access-class 20 in
 privilege level 15
 login local
 transport input ssh
 transport output all
line vty 5 15
 access-class 20 in
 login
 transport input ssh
scheduler allocate 20000 1000
end
--> Inaccessible to the domain address of the internal server from the internal Internet
Is the domain name of the internal server different for users that are trying to reach it internally than externally ?
I am sorry for the late reply.
The domains are the same.
Hello
you will to hairpin your nat to accomplish this
the most simplistic way would to use domain less nat instead
interfacess
up nat enable
no ip nat inside/outside
nat commands
io nat aource xxx
no ip nat inside xxx
Kind Regards
Paul
If configured like that, is there no problem with the operation of 1, 2, and 3?
The site is far away so you need to check in advance.
