ISR 4000 ZBF, PBR, NAT on single in interface ?
kthned
Level 3
Level 3
I have ISR 4451-x router running zone base firewall and NAT.
Working setup
ip route 0.0.0.0 0.0.0.0 x.54.23.254 interface GigabitEthernet0/0/0 description Internet ip address x.54.23.210 255.255.255.248 no ip redirects no ip unreachables no ip proxy-arp ip nat outside ip verify unicast reverse-path zone-member security OUTSIDE negotiation auto ip virtual-reassembly ! interface GigabitEthernet0/0/1 description inside ip address 172.16.4.10 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp ip nat inside ip verify unicast reverse-path zone-member security INSIDE negotiation auto ip virtual-reassembly
During a change window we have to remove the default route due to some reason so I created a Policy base route to route traffic to int gi0/0/0
no ip route 0.0.0.0 0.0.0.0 x.54.23.254
route-map internet deny 10
        match ip address PrivateNet-rfc1918 ! send dest.address == RFC 1918 to global route table
route-map internet permit 20
        match ip address ALL-internet ! send internet trafic to int gi0/0/0
        set ip next-hop x.54.23.209
           ip policy route-map internet
Just after applying PBR on inter gi0/0/1, we lost all TCP connctions but not UDP session
Half-open Sessions
Session ID 0x00667A6F (10.83.32.179:54761)=>(17.248.146.42:443) https SIS_OPENING
Created 00:00:10, Last heard 00
Bytes sent (initiator:responder) [0:0]
I can see th NAT was OK & UDP trafic had establish session. So the question is what happened to ZBF when PBR ticked over to control the traffic. is there any feature in compatibity ?
5 Replies 5
Hello
Re-apply your default and remove the route-map stanza 10 and test again.
conf t
no route-map internet deny 10
Kind Regards
Paul
Actually as soon as i remove PBR from interface and added default route it work. but that is like going back to point zero.
conf t
not understand your point if I remove stanza 10 and add default route so it would be the same thing i both ways ? i.e. sending traffic to  x.54.23.254 by default gateway and PBR ?
Hello
 if you just want everything to go via a different next hop then you DONT have to PBR you only need to change the default to route.
However I am assuming that you just want to PBR only specific hosts towards a different next hop address and not everything -If so then you'll need both the default route and the PBR next hop ip address
So the route-map only needs to match on the traffic that you want PBR and all other traffic will go via the default route
Kind Regards
Paul
Hej Paul
yes I understand your point. Actually we move default gateway to another interface that is by default-originate from the ospf peer. I have implemented PBR many times so I have a good understanding on the PBR and default routing table.
But here my question is why ZBF shows half open connections :( . WHY udp establish connection and why tcp half open.
I see the traffic traffic going outside and never returning
Again as soon as i remove PBR all TCP connection trafic work. Strange.
Hello
Looking at your configuration I dont at this time that the ZBFW is the issue, the next-hop address is in the same subnet and via the same outside interface than your previous default route -  Is the PBR next hop reachable.
What I do see is your not specifying the next hop for the rest of the traffic not captured by your route-map
Kind Regards
Paul
