isr 4221 turns off
otsukakong
hi guys
I have a lot of 4221 but faced the problem for the first time
when entering the conf mod, the cisco turns off, helps to switch the power plug. At the moment, it has been taken out of use, the new cisco works stably. Debugging does not repeat the problem. What do you think it could be?
the problem is clearly not in the power supply, as the problem only occurred when entering configuration mode, and all other nodes in the rack worked stably
ios xe 16.06.03
lic ipbasek9
marce1000
 - Attach a console, observer the console-output when this happens and or you may post results here.
 M.
Leo Laohoo
If the router "turns off" when going into configuration mode, then it is a hardware issue.
You may want to contact Cisco TAC and get them to do an EFA (field analysis).
balaji.bandi
if you have running config in hand please post, also post show version full.
BB
