isr 4300 how to put up the giga 0/0/1 without cable connected
Hi and thanks for support,
in the hold router I knew the command to bringing the fastethernet state up , for example no autostate or not keeplive or keeplive (don't remember).
Which is the commands use in ISR router for put up the Giga without cable connected ?
thanks a lot
Roberto
Hello Roberto,
the old ethernet and some fast ethernet interfaces could be put up/up with
int fa0/0
no keepalive
even if no cable was connected to them
I don't think modern GE ports can support this trick. I used it 16 years ago or even more.
If you need a logical interface to be used for testing IP connectivity you can use a loopback interface.
Cisco routers support multiple loopback interfaces and they support also subnet masks not only /32.
This is the common way of performing tests now.
the loopback command  in a physical interface should be supported on serial, ATM and POS interfaces for troubleshooting purposes.
Hope to help
Giuseppe
5 Replies 5
it used to be 'loopback' interface configuration mode, not sure if that command is valid on the 4331...
4331#conf t
4331(config)#interface GigabitEthernet0/0/1
4331(config-if)#loopback ?
thanks , I tried but status and protocol down down
no keepalive
Hello Roberto,
int fa0/0
no keepalive
Hope to help
Giuseppe
thanks a lot Giuseppe,
yes it's a best way for testing. I liked that command for not change the configuration and then come back after test again.
