Cisco GRE Tunnel Speed Issue MTU/MSS? Somethging Else? I'm Stumped
Greetings!
I have a Cisco 3945E 15.4(3)M1 (Upgraded from a 2851) Router connected to a cable modem this, in turn connects via a plain GRE tunnel to a cloud instance and on to the internet.
The tunnel and endpoints are up and running. Traffic flows in both directions and routes properly. I have a 400 mb/s pipe at the Cisco end and a much larger one at the cloud instance end. I was using LISP before in a similar situation and was getting 300+ mb/s. With the new setup (Either Router!)I am down to 50 mb/s. I MUST have a misconfig issue someplace. I have checked CPU load on the router (<30%) and nload on the Linux Instance (Centos 7) shows the 50 mb/s with essentially zero CPU load.
I have calculated and deployed an MTU of 1476 for the Tunnel and 1436 as the MSS on both sides. (Client machines are still at 1500 default)
My newest basic configs are:
Cisco Router (Abridged for clarity)
version 15.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Router3945E
boot-start-marker
boot-end-marker
enable secret 5
enable password
no aaa new-model
ip domain name madeup.net
ip name-server 8.8.8.8
ip name-server xxx.xxx.xxx.xxx
ip cef
no ipv6 cef
multilink bundle-name authenticated
cts logging verbose
crypto pki trustpoint TP-self-signed-xxxxxxxxx
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-xxxxxxxxxx
 revocation-check none
 rsakeypair TP-self-signed-xxxxxxxxxx
crypto pki certificate chain TP-self-signed-xxxxxxxxxxx
 certificate self-signed 01 nvram:IOS-Self-Sig#2.cer
voice-card 0
license udi pid C3900-SPE250/K9 sn xxxxxxxxxxxx
hw-module pvdm 0/0
username xxxxxxxx privilege 15 secret 5 $
redundancy
ip tcp path-mtu-discovery
no ip ftp passive
ip scp server enable
bridge irb
interface Loopback0
 ip address 201.xxx.xxx.xx 255.255.255.0
interface Tunnel0
 bandwidth inherit
 ip address 192.0.3.3 255.255.255.252
 ip mtu 1476
 ip tcp adjust-mss 1436
 tunnel source 61.203.212.230
 tunnel destination 181.251.205.33
 tunnel path-mtu-discovery
interface GigabitEthernet0/0
 description connection to CABLE MODEM (DHCP)
 ip address dhcp
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description Connection to 24-port unmanaged switch 201 LAN
 ip address 201.xxx.xxx.x 255.255.255.0
 ip tcp adjust-mss 1400
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/3
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 128.0.0.0 Tunnel0
ip route 128.0.0.0 128.0.0.0 Tunnel0
ip route 181.251.205.33 255.255.255.255 61.203.212.230
nls resp-timeout 1
cpd cr-id 1
snmp-server community public RO
control-plane
bridge 1 protocol ieee
bridge 1 route ip
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
 shutdown
line con 0
line aux 0
line vty 0 4
 password XXXXXXXXXXXXX
 login local
 transport input ssh
scheduler allocate 20000 1000
end
The Centos 7 Side is pretty simple:
The IPCFG_ETH0 on the Instance Centos 7 Box
MTU 1500
DEVICE="eth0"
BOOTPROTO="dhcp"
ONBOOT="yes"
TYPE="Ethernet"
NM_CONTROLLED="no"
IPV6_AUTOCONF="yes"
IPV6INIT="yes"
NOZEROCONF="yes"
ZONE=public
The IPCFG_TUN0 on the Instance Centos 7 Box
MTU 1476
DEVICE=tun0
BOOTPROTO=none
ONBOOT=yes
TYPE=GRE
PEER_INNER_IPADDR=192.0.2.2
PEER_OUTER_IPADDR=68.x.x.x
MY_INNER_IPADDR=192.0.2.1
Bear in mind I am also using BGPD to announce a /24 publicly and routing that /24 through the Tunnel (201.x.x.x)
Any ideas??? I believe there is an MTU/MSS issue someplace, but I have not been able to diagnose this.
 Weird that it's limited at just around 50 mbps??
Thanks for any help!
Rick
to be honest, I don't fully understand your topology.
--> ip route 181.251.205.33 255.255.255.255 61.203.212.230
You have a static route to the tunnel destination, with the next hop being the tunnel source ?
Can you provide a schematic drawing of your topology including the IP addresses used (and where they are used) ?
I changed the numbers for security purposes... Let me clarify:
interface Tunnel0
 bandwidth inherit
 ip address 192.0.2.2 255.255.255.252
 ip mtu 1476
 tunnel source 67.xxx.xxx.xxx.186 (Our Spectrum Assigned IP from Gig0/0)
 tunnel destination 173.xxx.xxx.xxx (Our Virtual Instance IP Adress of the Centos 7 Box)
 description connection to Spectrum (DHCP)
 ip address dhcp
 duplex auto
 speed auto
 ip address 203.xxx.xxx.xxx.1 255.255.255.0 (Our IP/24)
 duplex auto
 speed auto
 no mop enabled
ip route 173..xxx.xxx.xxx.xxx 255.255.255.255 67.xxx.xxx.1 (From CENTOS box To Spectrum Modem)
end
It does work....just the speed is way off....
Essentially, I have a Instance announcing our /24 to the world via BGP. That /24 is sent down the tunnel and to the Lisco and routed to the appropriate machines on the LAN.
Used to work fantastically using LISP, even o the 2851. Now using, an allegedly simpler, system, it's very slow.
Rick
Rick
Hello?
Anyone Know what's going on here?
David
