11-12-2021 01:00 PM
If provided a Public WAN IP and a set of Public LAN IPs, where would I assign the Public LAN IPs?
I have the WAN IP assigned to the Gb0/0/0 Port.
I am unable to assign the LAN Public IPs to the actual NIM card slots, so would I assign the Public LAN IPs to VLANs?
Solved! Go to Solution.
11-30-2021 08:17 AM - last edited on 12-01-2021 11:24 PM by Translator
So it's solely a NAT thing is what I think you're saying. I was trying to do PAT/NAT overload to accomplish this, but I didn't get very far due to an error.
I ran these commands but I got an error after the second one:
ip nat pool HbugPool 209.X.X.X 209.X.X.X netmask 255.255.255.192
ip nat inside source list 10 pool HbugPool overload
Error: Cannot change mapping's source type, or the mapping already exists; remove mapping first to make change.
I then removed my static NAT “band aid” that I have in place allowing one server to have the 209.X.X.X address temporarily, but got the same message after removing it so I put that static NAT back in place.
I've attached my running config.
11-30-2021 10:17 AM - last edited on 12-01-2021 11:26 PM by Translator
Hello
Your nat configuration looks like it has statements that are not necessary, pointing to the wrong wan interface, conflicting access-list or ones that don’t even exist and multiple overload statements that just single one could accomplish?
Suggest the following:
no ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
no ip nat pool testnet 209.Y.Y.Y 209.Y.Y.Y netmask 255.255.255.192
no ip nat pool HbugPool 209.X.X.X 209.X.X.X netmask 255.255.255.192
no ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
no ip nat inside source list 15 interface GigabitEthernet0/0/1 overload
no ip access-list standard 1
no ip access-list standard 10
no ip access-list standard 15
ip access-list standard10
deny(specfic lan subnet)
deny host 192.168.1.100
deny host 10.10.10.197
deny host 10.10.10.7
deny host 10.10.10.32
deny host 192.168.1.101
deny host 192.168.2.50
permit 10.0.0.0 0.255.255.255
permit 192.168.2.0 0.0.0.255
permit 192.168.1.0 0.0.0.255
permit 172.16.0.0 0.0.255.255
permit etc...
ip access-list standard newpat
permit (specfic lan subnet)
ip nat pool new-public-ip y.y.y.y y.y.y.y netmask x.x.x.x
ip nat inside source list newpat pool new-public-ip
11-30-2021 11:35 AM - edited 11-30-2021 11:37 AM
Are we denying those hosts so I can utilize the static NAT I've already put in place? Also, I'm not sure what (specific lan subnet) is... Sorry I'm learning as I go.
11-30-2021 12:17 PM
Hello
Yes
No need to have those hosts in the dynamic pat pool if you have specific static entries for them, unless you wish those internal hosts to reach additional ports not statically assigned?
Thats just a remark to say the lan subnet you wish to be natted to the new public address needs to be entered here
11-30-2021 06:24 PM - edited 11-30-2021 06:24 PM
@paul driver Came in after hours and was able to get this working as I wanted it. Tried what you said once, and lost myself Internet access somehow. Reloaded and tried what you said above again after clearing the NAT translation list clear ip nat translation * and it worked (not sure if it was coincidence or not). Reloading to a point before all my failed configuration test attempts I kept making probably didn't hurt either lol.
11-30-2021 11:17 PM
Hello
That’s good news-thank you for the feedback and marked solution
