ISR 4331 and Virgin Hub 3
lcsted
Hi Guys,
In the process of creating my home lab/network and I have got hold of an ISR 4331 router to replace my 2811 as the throughput was throttling my 350Mbs to about 60-80Mbs.  Can anyone confirm if this will still work as a replacement (I know it's probably overkill but it was free)?
Virgin Hub 3 is in modem only mode so just want to connect the WAN eth from the hub to the 4331 and then configure the router to handle the rest. Hopefully, there shouldn't be any issues other than my abilities to configure the router.
Cheers Ted
Mark Malone
That wont be able to handle a 350mbs line it will work though, i think from memory it 300mbps full dup max so 150mbs each way , we use an ASR 1000
